Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
  • 1.  Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
    Posted Apr 28, 2019 04:38 PM
    HI There
    I'm workng on a POC deployment which consit below equipment
    Cisco WLC wit AP
    Aruba IAP Cluster
    Aruba MC VA (Standalone) wit AP
    Clearpass 6.7.9 (Single Instance)
    I'm working on a Guest Self-registration with Mac Cashing deployment.
    I've managed to get everythng to work on all devices mobile devices including registration, mac auth and web login accross all platforms.
    However I have an issue when trying to self register Windows 10 wireless client while connecting to Guest hosted by VMC controller
    After sucessfull regustration client cannot go through the securelogin.....and ending up with Deny Access URL massage and is redirected back to the portal page again.
    This Is only happening with Windows 10 Clients and Aruba VMC contollers, Aruba IAP works just fine with the same client and CMC works with other mobile and smart devices.
    Any advice is highly appreciated
    Many Thanks
    Jack
  • 2.  RE: Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
    Posted Apr 29, 2019 03:08 AM
    Hi Jack,
    I have had similar issues in the past. Are you using the default Aruba certificate? “Secure login.arubanetworks.com”?
    This is one of the main issues I have this problem and the resolution for me is to get a publicly signed certificate as the default cert from Aruba is being revoked as it was compromised a few years ago.
    Ben
  • 3.  RE: Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
    Posted May 01, 2019 07:14 AM
    Hi There
    Yes im still using default Certificate as this is for demo lab porpuses
    Are there any other ways around this problem ?
  • 4.  RE: Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
    Posted May 01, 2019 07:19 AM
    Use HTTP instead of HTTPS. But that is not advisable for production
  • 5.  RE: Aruba VMC 8.3.6 and Clearpass 6.7.9 Guest Access Issue
    Posted May 02, 2019 12:16 PM
    Indeed, as mentioned above you can use http instead of HTTPS in this case. However, the recommended way would be to get a publicly signed certificate.
    Thanks, Ben
