Aruba VMC AOS8.3 License Server Client Share Problem Need Help!
  • 1.  Aruba VMC AOS8.3 License Server Client Share Problem Need Help!
    Posted Jul 18, 2018 09:37 PM
    We have Two Aruba VMC on Public Internet, please take a look the followed pictures
  • 2.  RE: Aruba VMC AOS8.3 License Server Client Share Problem Need Help!
    Posted Jul 18, 2018 09:41 PM
    1.The Licenser Server ip is 172.31.4.51  1:1 Nat to Public IP 47.105.111.35 Work at AOS8.3 VMC Standalone
    (AOS83) [mynode] #show ip interface bri
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP
    vlan 1 172.31.4.51 / 255.255.240.0 up up
    loopback unassigned / unassigned up up
    mgmt unassigned / unassigned up up
    (AOS83) [mynode] #show image version
    Partition : 0:0 (/mnt/disk1) **Default boot**
    Software Version : ArubaOS 8.3.0.0 (Digitally Signed SHA1/SHA256 - Production Build)
    Build number : 64659
    Label : 64659
    Built on : Sat Apr 28 04:36:21 UTC 2018
    Partition : 0:1 (/mnt/disk2)
    Software Version : ArubaOS 8.2.1.1 (Digitally Signed SHA1/SHA256 - Production Build)
    Build number : 65265
    Label : 65265
    Built on : Sat Jun 9 17:20:32 UTC 2018
    (AOS83) [mynode] #show license limits
    License Limits
    Limit Value
    1000 Access Points
    0 RF Protect
    0 120abg Upgrade
    0 121abg Upgrade
    0 124abg Upgrade
    0 125abg Upgrade
    1000 Next Generation Policy Enforcement Firewall Module
    0 Advanced Cryptography
    0 Service provider AP
    0 WebCC
    0 Beta AP
    0 MM-VA
    1000 MC-VA-RW
    0 MC-VA-EG
    0 MC-VA-IL
    0 MC-VA-JP
    0 MC-VA-US
    0 VIA
    (AOS83) [mynode] #show license server-table
    License Server Table for pool / profile root
    Service Type PoolSize ExpiredLic ActualPoolSize UsedLic RemainingLic Warnings FeatureBit
    Access Points 2048 0 2048 0 2048 Some licenses expiring enabled
    Next Generation Policy Enforcement Firewall Module 2048 0 2048 0 2048 Some licenses expiring enabled
    RF Protect 0 0 0 0 0 None disabled
    Advanced Cryptography 0 0 0 0 0 None disabled
    WebCC 0 0 0 0 0 None disabled
    MM-VA 0 0 0 0 0 None disabled
    MC-VA-RW 1000 0 1000 0 1000 Some licenses expiring enabled
    MC-VA-EG 0 0 0 0 0 None enabled
    MC-VA-IL 0 0 0 0 0 None enabled
    MC-VA-JP 0 0 0 0 0 None enabled
    MC-VA-US 0 0 0 0 0 None enabled
    VIA 0 0 0 0 0 None enabled
    aggregate License aggregate table
    box Show box license information
    client-table License client-table entries
    debug Debug
    heartbeat License heartbeats
    key Show single license key's information
    keys Show license keys information based on feature/license
    type
    limits Current license limits
    passphrase Show passphrase for license generation
    platform-limits Current platform license limits
    pool-profile Show license pool profile
    remote License management remote command
    server-table License server-table entries
    verbose Verbose output (deprecated, output is always verbose)
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show license heartbeat
    % Incomplete command
    stats License stats
    (AOS83) [mynode] #show license heartbeat stats
    License Server Heartbeat Table
    Client IP Address Mac Addr HB Req HB Resp Total Missed Last Update (secs. ago)
    172.31.4.51 00:16:3e:05:a5:40 97 97 0 17
    (AOS83) [mynode] #ping 106.14.2.163
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 106.14.2.163, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 17.654/17.7424/17.845 ms
    (AOS83) [mynode] #
  • 3.  RE: Aruba VMC AOS8.3 License Server Client Share Problem Need Help!
    Posted Jul 18, 2018 09:55 PM
    2.The License Client is also AOS8.3 VMC, It's Public IP is 106.14.2.163 there are also 1:1 Nat from local ip 172.19.42.114 to 106.14.2.163
    We can not get license shared from server why ? and we test them work well at local network without NAT.anybody can help to check the reason ?Thanks a lot.
    (AOS83) [mynode] #show running-config
    Building Configuration...
    version 8.3
    hostname "AOS83"
    clock timezone America/Los_Angeles -8
    location "Building1.floor1"
    controller config 1
    license server-ip 47.105.111.35
    ip NAT pool dynamic-srcnat 0.0.0.0 0.0.0.0
    ip access-list eth validuserethacl
    permit any
    (AOS83) [mynode] # ping 47.105.111.35
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 47.105.111.35, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 17.683/17.7812/17.872 ms
    (AOS83) [mynode] #
    Last login: Thu Jul 19 01:38:33 2018 from 111.37.20.221
    vlan 1 172.19.42.114 / 255.255.240.0 up up
    Label : 64659
    Label : 64659
    License Client Heartbeat Table
    Server IP Address Mac Addr HB Req HB Resp Total Missed Last Update (secs. ago)
    47.105.111.35 00:16:3e:02:56:22 137 0 137 4133
    172.19.42.114 00:16:3e:02:56:22 5096 5096 0 4133
    (AOS83) [mynode] #show license client-table
    Built-in limit: 0
    License Client Table
    Service Type System Limit Server Lic. Used Lic. Remaining Lic. FeatureBit
    Access Points 1000 0 0 0 enabled
    Next Generation Policy Enforcement Firewall Module 1000 0 0 0 disabled
    RF Protect 1000 0 0 0 disabled
    Advanced Cryptography 4096 0 0 0 disabled
    WebCC 1000 0 0 0 disabled
    MM-VA 1001 0 0 0 disabled
    MC-VA-RW 1000 0 0 0 enabled
    MC-VA-EG 1000 0 0 0 enabled
    MC-VA-IL 1000 0 0 0 enabled
    MC-VA-JP 1000 0 0 0 enabled
    MC-VA-US 1000 0 0 0 enabled
    VIA 16000 0 0 0 enabled
    Press 'q' to abort.
    (AOS83) [mynode] #
  • 4.  RE: Aruba VMC AOS8.3 License Server Client Share Problem Need Help!
    Posted Jul 18, 2018 10:30 PM
    we can not get license shared from Lic server ! why ?
