last person joined: 7 hours ago
Aruba vs Extreme networks
  • 1.  Aruba vs Extreme networks
    Posted Nov 01, 2017 10:22 AM
    I've got a customer that wants to know why he should pick IAP-305 over http://www.extremenetworks.com/product/wing-ap-7522/
    He will be using this network mostly for typical officework but also for their warehouse. I know that Aruba has wave2 and is 3x3 but in scenario like this where that might not make that much difference, why should he go for Aruba?  (He is also considering IAP-207 instead of IAP-305)
  • 2.  RE: Aruba vs Extreme networks
    Posted Nov 01, 2017 06:58 PM
    You should reach out to your Aruba rep for some help determining and helping position the pros and cons
    #AirheadsMobile
  • 3.  RE: Aruba vs Extreme networks
    Posted Nov 01, 2017 11:16 PM
    he may want to use iap277 for warehouse due to integrated directional antennas
  • 4.  RE: Aruba vs Extreme networks
