Aruba WIPS
This thread has been viewed 16 times
  • 1.  Aruba WIPS
    Posted Sep 14, 2022 07:42 AM
    dear expert
    we have 2 wirless setup aruba and mist
    we had issue when user try to connect mist ap user cannot authenticate
    i think aruba showed mist as rouge
    how to troubleshoot in aruba controller in this issue
    thanks to support
  • 2.  RE: Aruba WIPS
    MVP GURU
    Posted Sep 14, 2022 07:44 AM
    Are you using the same SSID on both? If so, I would suggest changing the names to be something different. You will not be able to see why authentication was not successful on the MIST AP on the Aruba Controller. You would want to check your MIST dashboard, and maybe check Marvis.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Aruba WIPS
    Posted Sep 14, 2022 09:10 AM
    An access point is detected as a rogue when it is seen on the wireless and wired at the same time by an Aruba device.  By default there is only detection and not protection, so it should not interrupt any authentication with third-party devices.
  • 4.  RE: Aruba WIPS
    Posted Sep 14, 2022 08:50 PM
    by default your IDS protection should be off.
