last person joined: 10 hours ago
Aruba Wireless Controller
  • 1.  Aruba Wireless Controller
    Posted Apr 30, 2024 10:49 AM
    Dears,
    Hope you are doing well !
    Apologize but i need clarification please now i want to migrate from aruba virtual controller to aruba controller 7010 and i install 8 Access Points
    Will i need license or i can control those APs without license
  • 2.  RE: Aruba Wireless Controller
    Posted Apr 30, 2024 01:02 PM
    Licensing is required.  At a minimum you'll need AP licenses.
    Carson Hulcher, ACEX#110
  • 3.  RE: Aruba Wireless Controller
    Posted Apr 30, 2024 01:55 PM
    Mohamed,
    If you are shutting down your virtual controller, you likely can "move" your licenses (AP, PEF-NG, RFP, etc.) to the new controller. Talk to your reseller or to Aruba TAC to see if a move is possible.
    Brad
  • 4.  RE: Aruba Wireless Controller
    Posted May 06, 2024 08:53 AM
    Brad,
    Actually i manage and control Access Points through Virtual controller without buying any license so i ask if i moved to physical controller
    will i need license or i can manage them also without buying any license ?
  • 5.  RE: Aruba Wireless Controller
    Posted May 06, 2024 10:23 AM
    Any installation involving a Mobility Controller will require licensing.
