Aruba Wireless Network speed is unstable
  • 1.  Aruba Wireless Network speed is unstable
    Posted Dec 17, 2015 07:49 AM
    my wireless speed is not stable on operation room in my hospital out side the room its working fine i have 3 Aruba Controllers master locale locale and Aruba 105 APs .
    what could be the problem and what is the solotion .
    Note. my network is in hospital and the problem in  Opration Room haveing medical equiped room .
    Waqar.
  • 2.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 17, 2015 07:58 AM
    Where are the access points mounted?
    What devices is the WLAN unstable with?
  • 3.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 17, 2015 10:08 AM
    dear Sir.
    AP is Mounted outside the OR .
    the device is HP Z book 17 G2 leptop .
  • 4.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 17, 2015 10:47 AM
    Does that area of the hospital have lead lined walls?
    Sent from Nine
  • 5.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 18, 2015 08:31 AM
    its an operation room for sure it will be lead lined walls .
    tell me the solution please .
  • 6.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 18, 2015 08:35 AM
    You probably need to hire a local expert who can tell you about your physical mounting options. We cannot easily advise you since we cannot visit your site.
  • 7.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 18, 2015 09:15 AM
    If they're lead lined walls, you'll have to put the AP in the room.
    Sent from Nine
  • 8.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 18, 2015 09:39 AM
    Not that it's cost effective, but if you have to deploy an AP inside the room, use the AP-275 and remove the plastic solar shield (not required but the shield could protect areas that could lead to bacteria and other pathogens to remain). It's IP66/67 rated and can sustain exposure to water, spray wash, etc. It can be mounted up higher and yet still survive exposure to the regular cleanings and decontamination. The 275 also supports conduit directly into the ethernet port, which would allow the protection of the ethernet from said cables, and provide greater prevention for any contaminants to be left behind after cleaning.
    Just a thought. While the 275 is a bit more expensive (for a reason), the cost of a 275 is a drop in the bucket compared to the cost of maintaining an operating room.
  • 9.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 19, 2015 01:50 AM
    appropriate sir i will try that way as you directed.
    thanks
  • 10.  RE: Aruba Wireless Network speed is unstable
    Posted Dec 17, 2015 08:38 AM
    You should start by looking at the RF health ( Utilization / Interference) on the controller dashboard
    How many SSIDs are you running ?
    Do you have drop broadcast/multicast enabled?
    Are you only experiencing issues in that location?
