"first have GRE decapsulation to get back the 802.11 frame, then decryption" is for tunnel mode.
Original Message:
Sent: May 09, 2023 11:27 PM
Subject: Aruba Wireless Traffic flow - validation (diagram)
Hi Herman, in the diagram, was this for the Tunnel mode bit or Decrypt mode?
Original Message:
Sent: May 08, 2023 04:32 AM
Looks quite accurate; just in Step 5, you will first have GRE decapsulation to get back the 802.11 frame, then decryption.
In step 3, the authentication will happen at the controller and from the client device, not at the AP; but diagram is not fully clear on where the authentication happens.
Think this (old) presentation has some good slides on Tunnel/Bridge/Decrypt-Tunnel.
Original Message:
Sent: May 07, 2023 03:36 PM
Hi guys,
I did up a traffic flow diagram explaining how traffic flows (high-level) from User to controller.
Could someone please validate to see if I am on the right track?
Many thanks
