Aruba wlan bridge mode
  • 1.  Aruba wlan bridge mode
    Posted Jan 03, 2020 04:18 AM
    Hello everyone,,,
    i want to working in  mode that the traffic not go to the controller
    my net build with MM-VA and MD the AP connected to the MD
    and its fine but i want to create ssid that working even if the controller ununreachable .
    i config ssid in bridge mode and then connected to the ssid when i disconected the MD the radio AP becom orange and my connection go down...
    from what i now the bridge  can work without the controller when the client already connected..
    do i miss somthing ?
    the version of the controller 8.3
    Thanks.
  • 2.  RE: Aruba wlan bridge mode
    MVP EXPERT
    Posted Jan 03, 2020 05:51 AM
    In bridge-mode you will loose a lot of functionality and flexibility. Beter use redundant controllers. You have a Mobility Master so you can use clustering for high availiablity, seemless failover and live-upgrades.
    ArubaOS 8.4 User Guide Page 1136 (link)
    In the ssid virtual AP profile you can set a "operating mode" value to backup or always. When configured as always the SSID stays up while the WAN Uplink is down, but this not true for a CAP that is managent by a controller, it still need to exchange management packets with the controller.
    It could be worked when you configured a CAP as RAP (Remote Access Point). But my advise is to keep using tunnel-mode and make use of redunant controllers in a cluster.
    For references see the RAP support modes.
  • 3.  RE: Aruba wlan bridge mode
    Posted Jan 03, 2020 06:04 AM
    If you need access points to survive without a controller, I would also consider Aruba Instant
