Aruba WLC how to remove generated CSR
  • 1.  Aruba WLC how to remove generated CSR
    Posted Dec 08, 2016 11:45 AM
    I've generated CSR file from Aruba WLC. Now it's possible that I need to remove this CSR and generate a new one.
    Problem is that I used Common Name : "WLC-name", not IP
    "WLC-name" is not resolvable in customer network (no DNS record available).
    I'll ask if they can add DNS record but if this is not allowed, how to remove the CSR. I can't generate new CSR since there is active one 'alive' (Management > Certificates > CSR - View Current shows my current CSR)
    Br
    Juha-Pekka
  • 2.  RE: Aruba WLC how to remove generated CSR
    Posted Dec 08, 2016 11:54 AM
    What version of ArubaOS is this?
  • 3.  RE: Aruba WLC how to remove generated CSR
    Posted Dec 08, 2016 12:08 PM
    So, I am on 6.5.0.1 and I can submit another CSR after a previous CSR.  I am not sure exactly when that was fixed...
  • 4.  RE: Aruba WLC how to remove generated CSR
    Posted Dec 08, 2016 03:10 PM
    I made new request using new Common name, that worked fine.
    So it might be possible to generate also a new any kind of CSR request in this vesion too even with same Common Name since I didn't try this option.
    Juha-Pekka
  • 5.  RE: Aruba WLC how to remove generated CSR
    Posted Dec 08, 2016 11:55 AM
    6.4.2.8
