Aruba6000 CLI does not show presence of Linecard
  • 1.  Aruba6000 CLI does not show presence of Linecard
    Posted Jun 09, 2018 11:28 PM
    Hi -
    I have Aruba 6000 Controller running  ArubaOS (MODEL: Aruba6000-US), Version 6.4.4.6
    I am working on providing Network Management Application Support for the device. In the process , I need to know the various cards installed on the device
    "show slots" does not indicate the presence of a line card  nor the "show inventory".
    However , when I do a "show port status" I see a listing of GE ports on the device.
    I want to know if there is a way via CLI or MIB query to know the cards ( supervisor & line card ) on the device.
    Attaching the o/p of  "show slots" & "show inventory"
    (Aruba6000) #show slots
    Slots
    Slot Status Card Type
    0 Present M3mk1
    1 Not Present N/A
    2 Not Present N/A
    3 Not Present N/A
    (Aruba6000) #show inventory
    Supervisor Card slot : 0
    Mobility Processor : FPGA Rev 0x13021320
    Mobility Processor Assembly# : 2010027B
    Mobility Processor Serial# : F00703416
    SC Assembly# : 2010026C (Rev:06.03)
    SC Serial# : F00703414 (Date:01/18/08)
    SC Model# : Aruba6000-US
    Mgmt Port HW MAC Addr : 00:0B:86:61:01:28
    HW MAC Addr : 00:0B:86:0A:03:00 to 00:0B:86:0A:03:7F
    XPLD Version : (Rev: 20)
    PEER Supervisor Card : Absent
    Line Card 0 : Not accessible from this SC
    Line Card 1 : Absent
    Line Card 2 : Absent
    Line Card 3 : Absent
    FAN 0 : OK, Speed High
    FAN 1 : OK, Speed High
    FAN 2 : OK, Speed High
    Fan Tray Assembly# : 2010007C (Rev:01.00)
    Fan Tray Serial# : F02081813 (Date:08/16/11)
    Back Plane Assembly# : 2010006B (Rev:02.06)
    Back Plane Serial# : A00006020 (Date:01/14/08)
    Power Supply type : Power One (400W)
    Power Supply 0 : OK (400W)
    Power Supply 1 : OK (400W)
    Power Supply 2 : Absent
    M3mk1 Card Temperatures : M3mk1 card 37 C
    : CPU 56 C
    AMP Card Temperatures : Processor Card 34 C
    : Mobility Processor 50 C
    : M3mk1 CPU Fan Speed 6490 RPMs
    M3mk1 Card Voltages : M3mk1 5000mV 4950 mV
    : M3mk1 3300mV 3340 mV
    : M3mk1 2500mV 2508 mV
    : M3mk1 1800mV 1780 mV
    : M3mk1 1500mV 1490 mV
    : M3mk1 1250mV 1260 mV
    : M3mk1 1200mV 1200 mV
    : M3mk1 IBC 12000mV 11730 mV
    : M3mk1 CPU CORE 1200mV 1200 mV
    : M3mk1 XGMII VTT 750mV 750 mV
    : M3mk1 VTT0(a&b) 900mV 890 mV
    : M3mk1 VTT1(c&d) 900mV 890 mV
    : AMP 3300mV 3320 mV
    : AMP 2500mV 2500 mV
    : AMP 1800mV 1800 mV
    : AMP 1500mV 1500 mV
    : AMP BCM 1200mV 1180 mV
    : AMP FPGA 1200mV(1) 1200 mV
    : AMP FPGA 1200mV(2) 1200 mV
    (Aruba6000) #show port status
    Port Status
    Slot-Port PortType AdminState OperState PoE Trusted SpanningTree PortMode Speed Duplex
    0/0 GE Enabled Up Enabled Yes Forwarding Access 1 Gbps Full
    0/1 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/2 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/3 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/4 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/5 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/6 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/7 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/8 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/9 GE Enabled Down Enabled Yes Disabled Access Auto Auto
    0/10 XG Enabled Down Enabled Yes Disabled Access Auto Auto
    0/11 XG Enabled Down Enabled Yes Disabled Access Auto Auto
  • 2.  RE: Aruba6000 CLI does not show presence of Linecard
    Posted Jun 11, 2018 03:05 PM
    The ports you're seeing with "show port status" are the physical ports on the M3 supervisor card, not ports on the line cards. I don't believe the M3 supported use of the line cards, where previous supervisors (Sup1 and Sup2) did. If the M3 did support line cards, it would have been in earlier software prior to AOS 6.
  • 3.  RE: Aruba6000 CLI does not show presence of Linecard
    Posted Jun 12, 2018 02:21 AM
    Hi Charlie -
    Thanks for your reply.
    Can I populate all the slots with M3 card ? [ if Iam running 6.4.x & above ]
    [https://www.cisco.com/c/dam/m/en_us/signaturetool/images/banners/standard/01_standard_ciscoblue.png]
    Udaya Bhaskar Chimakurthy
    Manager
    uchimaku@cisco.com
    Tel: +91 44 4052 1359
    Cisco Systems, Inc.
    SEZ-Unit4, SDB-7, GF,1F-4F ELCOT SEZ Campus, Sholinganallur
    CHENNAI
    600119
    India
    cisco.com
    [http://www.cisco.com/assets/swa/img/thinkbeforeyouprint.gif]
    Think before you print.
    This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
    Please click here for Company Registration Information.
  • 4.  RE: Aruba6000 CLI does not show presence of Linecard
    Posted Jun 12, 2018 10:56 AM
    Yes
