Wired Intelligent Edge
ArubaOS 16.08 User roles initial role per port
  • 1.  ArubaOS 16.08 User roles initial role per port
    Posted Sep 05, 2019 05:27 AM
    this is how you configure a global initial role:
    (config)# aaa authorization user-role initial-role ROLE-STR
    but how do you configure it at per-port level?
    On page 262 Aruba 2540 Access Security Guide for ArubaOS-Switch 16.08 is just an indication that this is possible.
    initial-role
    The default initial role “denyall” is used when no other role applies. If a client connects to the switch and lacks a user role associated, then the initial role is used. Any role can be configured as initial role using this option.Initial role can be configured at per-port level. The per port initial role takes priority over global initial role.
    Somehow I can't find any CLI reference guide for ArubaOS 16.08.
    What is the command to configure it at a per-port level?
  • 2.  RE: ArubaOS 16.08 User roles initial role per port
    MVP GURU
    Posted Sep 09, 2019 04:26 AM
    For me, it is a typo on documentation
    and you can use ClearPass for push a initial role by port...
