ArubaOS 6.0.2.1 bugs?
  • 1.  ArubaOS 6.0.2.1 bugs?
    Posted Feb 29, 2012 11:32 AM
    Dear all,
    My Aruba Controller using ArubaOS 6.0.2.1 , after i add the following command:
    (host)(config) # aaa xml-api server 10.12.13.14
    (host) (XML API Server "10.12.13.14") # key arubaxml
    (host)(config) # aaa profile wirelessuser
    (host)(AAA Profile "wirelessuser") # xml-api-server 10.12.13.14
    (host)(XML API Server "10.12.13.14") # key arubaxml
    The Aruba Controller could not to provide services normally. (e.g. User cannot access the Captive Portal server)
    Do i need to reload/reboot the Aruba Controller?
  • 2.  RE: ArubaOS 6.0.2.1 bugs?
    Posted Feb 29, 2012 02:22 PM
    Can you please put the config of your captive portal profile and intial user-role (ACL)?
  • 3.  RE: ArubaOS 6.0.2.1 bugs?
    Posted Feb 29, 2012 09:34 PM
    Dear all,
    Before I add xml-api command:
    aaa profile "AAA_CAPTIVE_PORTAL"
       initial-role "guest-logon-test"
       xml-api-server "10.12.13.100"
    user-role guest-logon-test
     captive-portal "captiveportal"
     access-list session allowall
    aaa authentication captive-portal "captiveportal"
       server-group "internal"
       protocol-http
       logon-wait cpu-threshold 95
       login-page "http://macau123.mo/captiveportal"
       no enable-welcome-page
       switchip-in-redirection-url
    After I add xml-api command:
    aaa xml-api server "10.12.13.14"                  <============ new add command
       key 718424a3e1105543cb22432da34
       xml-api-server "10.12.13.14"  <======= new add command
       protocol-http
    After I add these command , do I need to reload/reboot the Aruba Controller?
  • 4.  RE: ArubaOS 6.0.2.1 bugs?
    Posted Mar 01, 2012 12:04 AM
    You should not have to reload.  Can your clients resolve dns?
  • 5.  RE: ArubaOS 6.0.2.1 bugs?
    Posted Mar 01, 2012 12:19 AM
    Just wondering, did you allow acceess to your external erver ip in the captive portal ACL?
    By default Captive Portal ACL will not allow any HTTP/HTTPs traffic to go through and will dsn-nat it to port 8080 or 8081. In case of exernal captive portal, you need to put ACL in the top to allow HTTP/HTTPs traffic to your external web-server.
    Please go through the KB article answer id -124 and make sure config is correct.
    http://support.arubanetworks.com/Default.aspx?tabid=111&loc=https://kb.arubanetworks.com/cgi-bin/arubanetworks.cfg/php/enduser/std_alp.php?p_sid=g_xs7ZRk
    #AP124
  • 6.  RE: ArubaOS 6.0.2.1 bugs?
    Posted Mar 01, 2012 02:26 AM
    Dear cjoseph and aalap2,
    Before I add the xml-api command, the Aruba Controller working fine.
    After I add the xml-api command, some problem appear (e.g. client users cannot resolve DNS, cannot access captive portal server).
