ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
  • 1.  ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
    Posted Jun 03, 2016 05:45 AM
    Hi
    releasenotes say
    This section describes the important points to remember when configuring an L2 GRE tunnel with respect to
    tunnel-type:
    l ArubaOS 6.4.4.0 continues to support L2 GRE tunnel type zero, but it is recommended to use a non-zero
    tunnel type.
    l If both L2 and L3 tunnels are configured between end point devices, you must use a non-zero tunnel type
    for L2 GRE tunnels.
    im using simple MC3400 with campus AP105 and few RAP3-WN with basic plain RAP connection. how is there concerning regarding info from releasenotes regarding the L2 GRE tunnel type zero , im stuck in information how far this concern my setup so far.
    the RAP3wn are not zero-touch connected, they are connected with static user/pw/PSK like a classic RAP setup as i learned in 2010. im using CPSec internally for the campus APs and the VPN-services are just straight configured only for the RAPs , there are no L2TP users/IPSEC VPN users connecting direectly to the MC3400.
    someone can tell me regarding zero-tunnel in which case this affects perhaps to us ?
    thanks
    ben
  • 2.  RE: ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
    Posted Jun 03, 2016 07:23 AM
    Link to release notes?
    Just guessing that this only refers to site to site GRE tunnels, NOT GRE tunnels created by access points.
  • 3.  RE: ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
    Posted Jun 03, 2016 08:26 AM
    hi cjoseph,
    well the copy/paste info is just from releasenotes 6.4.x , it's everywhere mentioned in 6.4.x releasenotes and i just dont know if this concerns my setup at all .
    do you really want link to releasenotes , i dont think this helps as copy/paste is the same written there.
  • 4.  RE: ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
    Posted Jun 03, 2016 09:02 AM
    It only relates to site to site GRE deployments.
  • 5.  RE: ArubaOS 6.3.x -> 6.4.x upgrade / GRE Tunnel-Type Requirements
    Posted Jun 11, 2016 07:48 AM
    Hi Colin,
    Consider this as an example:
    interface tunnel 88
            description "Tunnel to anchor"
            tunnel mode gre 88
            tunnel source 172.16.32.1
            tunnel destination 192.168.15.210
            trusted
            tunnel vlan 888
    My question is this command: tunnel mode gre <num>   - is this <num> a 16-bit protocol type of the payload packet as per the GRE packet header in RFC 2784 ???
    In the example above, I use tunnel mode gre 88, and the config works.   I changed it to some other number, says 14, it also works.
    ArubaOS 6.4.4.0 continues to support L2 GRE tunnel type zero, but it is recommended to use a non-zero tunnel type.     So what is the real use of this <num> as in tunnel mode gre <num>?
    Kind regards
    Kenneth
