Wired Intelligent Edge
last person joined: 7 hours ago
ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
This thread has been viewed 55 times
  • 1.  ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Dec 12, 2018 05:00 AM
    I'd like to import a campus ap whitelist in the GUI (ArubaOS 8.3.0.4), but I can't seem to find information on what the file should look like. Anyone have an idea what the expected import file format and syntax is?
    import buttonimport buttonimport windowimport window
    Dante
  • 2.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Dec 12, 2018 11:58 AM
    whitelist has been created for a certificate-based RAP. This list can automatically be populated. The whitelist specifies the RAP name and AP group.
  • 3.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Dec 13, 2018 07:18 AM
    Maybe I should explain a little more:
    A customer want to be able to import a whitelist file containing MAC address, AP name and AP group for 500 APs he's going to deploy, so they get provisioned automatically with the correct name and group. Not talking about RAPs, but CAPs. In the screenshot I added in my initial message you can see a link that enables users to import a whitelist file. I'd like to know what the format and syntax of that file should be, tried with something basic like a csv file containing "<mac address>,<ap name>,<ap group>", but it's not accepted.
    Dante
  • 4.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Jan 31, 2019 06:02 AM
    Hi Dante,
    Just add them via CLI:
    whitelist-db cpsec add mac-address aa:bb:cc:dd:ee:ff ap-name AP-XXX-YYY-ZZZ
    https://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Control_Plane/Whitelists_on_Campus_and_Remote_APs.htm
    Thomas
  • 5.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Jan 31, 2019 01:39 PM
    Hi Thomas,
    Thanks for the suggestion, but I was already aware of that option and used it as a workaround.
    It's just annoying that the option to import in the GUI is available, but no example or documentation is available on the syntax. Which in effect renders the feature useless...
    Dante
  • 6.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted May 10, 2019 07:50 PM
    To add an entry the format is the following:
    00:00:00:00:00:00,<AP name>,<AP group>,<Description>
    If you do not want to configure an option, leave all commas in place.
    examples:
    80:8D:B7:01:02:03,MY-FIRST-AP,default,Aruba 315
    80:8D:B7:04:05:06,MY-OTHER-AP,,Aruba 315
    Please note as of now, I have not figured how or if one can update or remove an existing entry thru the import process.
    FYI - Aruba support was of no help in determining this information. :(
            So good luck if you call support to inquire about this option.
    Dan
  • 7.  RE: ArubaOS 8 Campus AP Whitelist Import: what is the expected format?
    Posted Apr 20, 2022 04:58 AM
    Hi Dan
    - you cannot replace any entry via the import function
    - you can just add new mac addresses (even if you have the same AP name)
    - as soon as you have a mac-address in the import-file which is already in the controller whitelist, the import of the whole file fails
    attached a .csv as example
    regards Michael
    Michael
    Attachment(s)
    csv
    whitelist-example.csv   488 B 1 version
