ArubaOS 8 - MD converted itself to a master
  • 1.  ArubaOS 8 - MD converted itself to a master
    Posted Jun 29, 2018 09:19 AM
    Hi All,
    I am working on a VMM with 2x 7205 controller deployments. When I rebooted one of the 7205 controllers after enabling DPI, it came back up as a "master", not an MD. There's no way for me to set the masterip, I get the error:
    ERROR: Command can be executed only on /md subtree.
    However, I can't cd to /md because it's a standalone.
    This is at a remote site with no hands. How can I convert back to an MD without a factory reset?
  • 2.  RE: ArubaOS 8 - MD converted itself to a master
    Posted Jul 01, 2018 07:30 AM
    Your only option might be Disaster Recovery:  https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Configuration_Hierarchy/Config_Hierarchy.htm?Highlight=disaster%20recovery
    If you can, please open a tac case to be guided through this.
  • 3.  RE: ArubaOS 8 - MD converted itself to a master
    Posted Jul 04, 2018 07:14 AM
    i have the same issue?
    Is there any way to convert a controller back to a MD?
    the device is interstate so console access will not be easy
  • 4.  RE: ArubaOS 8 - MD converted itself to a master
    Posted Jul 05, 2018 07:35 AM
    Hi Guv,
    Currently the only way to do this is a factory reset.
