ArubaOS 8: MM vs 7200 as master
  • 1.  ArubaOS 8: MM vs 7200 as master
    Posted Apr 23, 2018 04:23 AM
    i just found out that 72xx controller can act as master controller in ArubaOS 8 which i thought the master capability was removed and completely replaced by MM.
    i could not find any good document comparing MM vs 7200 master mode even in the VRD.
    can anyone point me somewhere this issue being explained?
  • 2.  RE: ArubaOS 8: MM vs 7200 as master
    Posted Apr 23, 2018 04:50 AM
    a 7200 can be a master, however you can not terminate AP's on it. you also lose the ability for some other functions that only the MM can provide.
    you need the MM if you want;
     - allways on network during controller failure
     - automated rf with AirMatch
     - in-service software upgrade
     - jabber support
     - centralised visability
  • 3.  RE: ArubaOS 8: MM vs 7200 as master
    Posted Apr 23, 2018 04:54 AM
    so basically, 7200 master is just a MM with minimized feature?
  • 4.  RE: ArubaOS 8: MM vs 7200 as master
    Posted Apr 23, 2018 05:01 AM
    With the 7000 as master in ArubaOS 8.0 (non-MM deployment):
    - The master controller must be a 7030 or above
    - Access points cannot terminate on the master (it takes the role of the MM, which also does not terminate access points)
    - Airmatch is not supported
    - Monitoring of things like UCC, Airgroup and Clients is individual to each controller (in an MM deployment it is centralized)
    - Controller clustering (hitless failover) is not supported
    - No Loadable Service Modules (you cannot upgrade parts of ArubaOS, you must upgrade all of it at one time)
    - All controllers must have the same version (in an MM deployment this is not a requirement).
    - Centralized Licensing does not support Licensing Pools if you use a 7000 controller as the master in 8.x
    Long story short, go the MM route for the best scalability, performance and flexibility..
  • 5.  RE: ArubaOS 8: MM vs 7200 as master
    Posted Apr 23, 2018 05:08 AM
    awesome. this clears it all.
