This post is about configuring the Controller for Virtual Intranet Access.
Included information on 'where in GUI' and the equivalent 'CLI command'.
Setup:
Aruba7005 Controller in standalone mode running ArubaOS Version 8.3.0.5.
VIA configuration requires that you first configure VPN settings and then configure VIA settings.
VPN Settings:
Enable VPN Server Module
You must install the PEFV license to configure and assign user roles.
GUI:
Mobility Controller -> Configuration -> System -> Licensing -> Inventory -> Click on + sign and add the license.![VIA License.jpg VIA License.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_efdd2a98cb944d44bf1542a6e8d7089a)
CLI:
license add <key>
Decide IKE Policy
ArubaOS support both IKEv1 and IKEv2 protocol to establish IPsec tunnels.
We will be using predefined default IKE policies "20", which has the following parameters, to establish the VPN tunnel.
Encryption: AES256
HASH: SHA
AUTHENTICATION: pre-shared
Diffie Hellman Group: 2
GUI:
Configuration -> Services -> VPN -> IKEv1 -> IKEv1 Policies
![IKEv1 Policy.jpg IKEv1 Policy.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_6de735d649ce47f2a9ff8f2b1935c41a)
Configuring the shared secrets
GUI:
Configurations -> Services -> VPN -> Shared Secrets -> IKE Shared Secrets
![Shared Secret.jpg Shared Secret.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_d1447ffde5684e44919b4053bb17a5a0)
CLI:
crypto isakmp key ****** address 0.0.0.0 netmask 0.0.0.0
Address Pool
Define the pool from which the clients are assigned addresses.
GUI
Configuration -> Services -> VPN -> General VPN -> Address Pool![Address Pool.jpg Address Pool.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_a8d150efe2b847c99956e8d2644acb24)
CLI:
ip local pool via 2.2.2.2 2.2.2.200
Define the DNS Server
Configure the IP addresses of the DNS servers that is pushed to the VPN client.
GUI
Configurations -> Services -> VPN -> General VPN -> Primary DNS Server
![Primary DNS Server.jpg Primary DNS Server.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_34f7fe6929274e0fa567950cf1c656c7)
CLI:
vpdn group l2tp client configuration dns 8.8.8.8
Enabling NAT-T
NAT traversal allows systems behind NATs to request and establish secure connections on demand.
GUI:
Configurations -> Services -> VPN -> General VPN -> Enable NAT-T
CLI:
crypto isakmp udpencap-behind-natdevice
VIA Settings:
VIA Authentication
Create an authentication profile to authenticate users against a server group.
GUI:
Configuration -> Authentication -> L3 Authentication -> VIA Authentication -> Add a new profile and set the server group to 'internal'.![Auth Profile.jpg Auth Profile.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_e326cc845382479792c7e54b27310658)
CLI:
aaa authentication via auth-profile "kapvia"
server-group "internal"
Adding local users:
GUI:
Goto Configuration -> Authentication -> Auth Servers
In 'Server Groups' -> Internal.
Click on 'Internal' and goto 'Users'
Add local user here.
![Adding Local Users.jpg Adding Local Users.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_115e20bc9b1d4ce18f544b0cb81abaa8)
CLI:
local-userdb add username kapil password ****** role default-via-role
VIA Web Authentication
Create the VIA web authentication which is a list of VIA authentication profiles.
The web authentication list allows the users to login to the VIA download page <https://<controller IP address>/via> to download the VIA client.
GUI:
Configuration -> Authentication -> L3 Authentication -> VIA Web Authentication -> Add a new web auth profile
![Web Auth.jpg Web Auth.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_75280be90b484401b2a5c4c48ddffbce)
CLI:
aaa authentication via web-auth "default"
auth-profile "kapvia" position 1
VIA Connection profile
Create the VIA connection profile which is a collection of all the configurations required by a VIA client to establish a secure IPsec connection to the controller.
A VIA connection profile is always associated to a user role, and all users that belong to that role use the configured settings.
When a user authenticates successfully to a server in an authentication profile, the VIA client downloads the VIA connection profile that is attached to the role assigned to that user.
GUI:
Configuration -> Authentication -> L3 Authentication -> VIA Connection -> Add a new connection profile
- Define the Server address
- Link the VIA Auth profile
- Mention the internal address that needs to be accessed by VIA
- Enable split tunneling
- Select the IKE Policy
![Connection Profile.jpg Connection Profile.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_ae5af28cb7584e489851caade222af30)
CLI:
aaa authentication via connection-profile "kap-con-via"
server addr "59.167.xx.xxx" internal-ip 10.10.101.1 desc "Aruba7005-Gateway" position 1
tunnel address 192.168.17.0 netmask 255.255.255.0
tunnel address 192.168.26.0 netmask 255.255.255.0
tunnel address 172.30.30.0 netmask 255.255.255.0
tunnel address 172.30.29.0 netmask 255.255.255.0
tunnel address 172.30.20.0 netmask 255.255.255.0
tunnel address 10.10.100.0 netmask 255.255.255.0
tunnel address 10.10.101.0 netmask 255.255.255.0
split-tunneling
ikev2-policy "10004"
ike-policy "20"
no windows-credentials
no domain-pre-connect
Create VIA roles:
Link the Address Pools and Connection Profile
GUI:
Configuration -> Roles & Policies -> Roles -> Modify the 'default-via-role'
CLI:
user-role default-via-role
pool l2tp via
via "kap-con-via"
access-list session global-sacl
access-list session apprf-default-via-role-sacl
access-list session allowall
access-list session v6-allowall
Verification Commands:
show crypto isakmp sa
show crypto ipsec sa
![crypto-ipsec-isamkp.jpg crypto-ipsec-isamkp.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_d6dc9bb4b7c94adb9b102d32802525f2)
show user![Users.jpg Users.jpg](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/734ec378cea74082a9fc8d66dfc46479_0a0c08ab1daf4a98bebd549a9e63c870)
Hope you find this post useful. Please post your feedback.
Kapildev Erampu
