ArubaOS 8.2 and Apple Captive Portal
  • 1.  ArubaOS 8.2 and Apple Captive Portal
    Posted Oct 18, 2017 12:19 PM
    Hi All
    Have anyone experienced a different behavior for the iOS devices using captive portal on a guest SSID on 8.2 ?
    In my case, all my iOS devices ( and a BQ Android 7.0 which implements the same check URL )  were attempting to access captiveportal.apple.com to get a success connection after upgrading to 8.2 whereas before I didn’t notice that.
    I had to add a whitelist to the captive portal profile to bypass the check and now all of the devices are working fine but I wonder if something in this regards has changed on 8.2
    Antonio
  • 2.  RE: ArubaOS 8.2 and Apple Captive Portal
    Posted Oct 18, 2017 12:31 PM
    Apple changed some of the behavior (as usual). It's being looked in to.
  • 3.  RE: ArubaOS 8.2 and Apple Captive Portal
    Posted Oct 18, 2017 12:37 PM
    Thank you Sir for the confirmation
  • 4.  RE: ArubaOS 8.2 and Apple Captive Portal
    Posted Dec 12, 2017 05:37 PM
    hey tim,
    made any progress on this investigation? I'm having same issues.
