Set points at a distance of 3 meters.
Connect the console mesh point. I understand there is an error, but where?
The console asks for a password, where can I get it?
What should I do next?
APBoot 1.5.5.7 (build 56398)
Built: 2016-09-08 at 14:04:05
Model: AP-27x
CPU0: P1020E, Version: 1.1, (0x80ec0011)
Core: E500, Version: 5.1, (0x80212051)
Clock:
CPU0: 800 MHz
CPU1: 800 MHz
CCB: 400 MHz
DDR: 333.333 MHz (666.667 MT/s data rate) (Asynchronous)
LBC: 25 MHz
L1: D-cache 32KB enabled
I-cache 32KB enabled
I2C: ready
DRAM: Configuring DDR for 666.667 MT/s data rate
DDR: 512 MB (DDR3, 32-bit, CL=5, ECC off)
POST1: memory passed
Flash: 32 MB
L2: 256 KB enabled
Power: 802.3at POE
PCIe1: RC, link up, x1
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 4360 00002 03 80000004 00000000 00000000 00000000
PCIe2: RC, link up, x1
00 00 14e4 4360 00002 03 a0000004 00000000 00000000 00000000
Net: eth0, eth1
Radio: bcm43460#0, bcm43460#1
FIPS: passed
Hit <Enter> to stop autoboot: 0
Checking image @ 0xee000000
Copying image from 0xee000000
Image is signed; verifying checksum... passed
SHA2 Signature available
Signer Cert OK
Policy Cert OK
RSA signature verified using SHA2.
[ 0.000000] Flash variant: default
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 8.3.0.0 (build 64659 / label #64659)
[ 0.000000] Built by p4build@pr-hpn-build09 on 2018-04-27 at 21:20:01 UTC (gcc version 4.5.1)
[ 0.000000]
[ 0.000000] Memory: 507788k/524288k available (10676k kernel code, 16500k reserved, 652k data, 472k bss, 7092k init)
[ 0.003001] Processor 1 found.
[ 0.113044] Brought up 2 CPUs
[ 0.190241] PCI: Probing PCI hardware
[ 0.233395] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.296389] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.358607] pci 0000:00:00.0: enabling device (0106 -> 0107)
[ 0.425702] pci 0001:02:00.0: enabling device (0106 -> 0107)
[ 5.619420] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
[ 5.694480] Amd/Fujitsu Extended Query Table at 0x0040
[ 5.756004] number of CFI chips: 1
[ 5.811238] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
[ 5.894794] /proc/gfar_eth0_stats created
[ 5.945086] fsl-gianfar ethernet.3: enabled errata workarounds, flags: 0x4
[ 6.028641] /proc/gfar_eth1_stats created
[ 6.167235] ad7418 1-0048: cannot read configuration register
[ 6.236387] ad7418 1-0049: cannot read configuration register
[ 6.305801] Enabling watchdog on CPU 0
[ 6.305810] Enabling watchdog on CPU 1
[ 6.395644] Masking ICV Error interrupt
[ 6.447005] ramzswap: num_devices not specified. Using default: 1
[ 6.519958] ramzswap: Creating 1 devices ...
[ 6.821703]
[ 6.821708] Starting Kernel SHA1 KAT ...Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
[ 6.830614] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
[ 6.831350] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
[ 6.831870] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
[ 6.832435] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
[ 6.867606] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
[ 6.868062] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
[ 7.534328] Completed Kernel SHA1 KAT
[ 7.579145] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 7.687753] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 7.759711] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 7.803509]
Populate AP type info
Domain Name: arubanetworks.com
No panic info available
[ 24.904955] p1020_soc: P1020 Misc Utils Driver version 1
Ethernet port 1 mode: active-standby
[ 40.402796] init_phy: PHY interface is SGMII
[ 40.456920] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 40.532898] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 40.621512] init_phy: PHY interface is SGMII
[ 40.675613] bonding: bond0: enslaving eth0 as a backup interface with a down link.
[ 40.838326] init_phy: PHY interface is SGMII
[ 40.892590] bonding: bond0: enslaving eth1 as a backup interface with a down link.
[ 41.253992] AP xml model 74, num_radios 2 (jiffies 20423)
[ 41.318630] apType 74 hw_opmode 0
[ 41.358241] radio 0: band 1 ant 1 max_ssid 16
[ 41.410362] radio 1: band 0 ant 1 max_ssid 16
[ 41.462478] init_asap_mod: installation:2
[ 41.510433] ethernet_device_event: dev eth0 is up
[ 41.567636] PHY: eth0 (mdio@ffe24000:00) - Link is Up - 1000/Full
[ 41.642984] ethernet_device_event: dev eth0 is changed, carrier: 1
[ 41.726766] firewall cpu: core-1
[ 41.810014] bonding: bond0: link status definitely up for interface eth0.
[ 41.891319] bonding: bond0: making interface eth0 the new active one.
[ 41.968498] bonding: bond0: first active interface up!
[ 42.030251] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
set device anul0 mtu to 2000
Starting watchdog process...
Aruba watchdog daemon started [2 thread(s)]
LLDP not sent yet, DHCP is waiting
Starting DHCP
net.ipv4.conf.all.arp_notify = 1
net.ipv4.conf.all.arp_notify = 0
net.ipv4.conf.br0.arp_notify = 1
[ 49.935418] wifi0: AP type AP-274, radio 0, max_bssids 16
[ 50.587010] wifi1: AP type AP-274, radio 1, max_bssids 16
Clearing P1020 PCIe Error Status
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
password: [ 57.703709] wl0: set MESH_ID(Bridge1, 7)
[ 59.059266] asap_vap_gone: Got vap gone notification on unknown vap:0:1
[ 60.215535] asap_vap_gone: Got vap gone notification on unknown vap:0:0
[ 61.310306] Got MTU config but no tunnel to AAC yet
[ 110.803574] aruba_enable_usb_block:556 Enabled USB
[ 110.860901] aruba_usb_power_control:1144 Enable USB power control for 224/225
[ 110.946402] ardmore_usb_power_control:1055 enabled the USB interface
[ 111.022488] Enabling eth1 due to power change [power profile 1]
[ 425.568115] wl0: set MESH_ID(RecoverySauy4UJbawglY4vf, 24)
