ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
  • 1.  ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
    Posted Oct 31, 2019 06:11 AM
    Hi AirHeads,
    the questions are regarding ArubaOS 8.4.X or 8.5.X
    Can I configure RAP as Multizone AP in Split-Tunnel working mode + Mesh portal or Mesh point, And if yes does the Mesh supporting voice/video capabilities.
    I will divide the question to couple of questions 😊
    • (CPSEC REMOTEAP)RAP – Multizone supported? (As far 8.2 8.3 8.4 8.5 I know that yes)
    • (CPSEC REMOTEAP)RAP  with Multizone , Does Split-Tunnel supported?
    • (CPSEC REMOTEAP) RAP  with Multizone as Mesh portal or Mesh point? With video/voice capabilities?
  • 2.  RE: ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
  • 3.  RE: ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
    Posted Oct 31, 2019 10:12 AM
    Thanks , BUT, The post you shared is a bit not updated.(Its seems it was published before 8.2.X )
    From UG 8.2 8.3 8.4 8.5
    • CPSEC can be hybrid in MultiZone
    • RAP mode do supportedin MultiZone
    • Mesh is supported in MultiZone
    But do SplitTunnel with RAP in Multizone supported ?
  • 4.  RE: ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
    Posted Oct 31, 2019 10:44 AM
    From 8.5.X UG:
    But in the same UG , it's written that only tunnel / decrypt tunnel can work in Multizone - so no Split-Tunnel avilable for multizone ap's?
    can rap be as multizone ?
    can rap that working multizone handle video/audio in mesh?
  • 5.  RE: ArubaOS 8.4 / 8.5 - RAP as Multizone AP in Split-Tunnel working mode / Mesh Portal/Point?
    Posted Oct 31, 2019 11:31 AM
    Let me correct my statement.
    Remote mesh + multizone is not supported.
