I can make AP specific settings from cli under a node. Where can I view those settings. If I try 'show ap-name <ap> ' I get the error "commands need to be executed on ..."
Can't find settings on webui or cli. Thank you.
on mm you have to go into the managed network and use
show configuration effective | begin "ap-name <ap>"
or mdconnect to the MD where you know the config ended up
and use "show ap-name <ap>" there
