Developer
Arubaos Ansible REST starting
  • 1.  Arubaos Ansible REST starting
    Posted Apr 01, 2020 07:29 AM
    Hallo,
    This is my first post here on Airheads.
    The company i work for is experimenting with Ansible for managing and basic configuring switches and firewalls.
    Everything works fine and i can use a couple of Ansible playbooks but when i try to run playbooks that make use of the REST api things go wrong.
    First of all, what is the best "method" or aruba-ansible module to manage and configure devices? Currently i try to use  aruba-ansible-modules and aruba-switch-ansible.
    As i understand, both have different methods and capabilities.
    I followed the aruba bots ansible series on Youtube and learned a lot from it.
    The (test)switch i use is a Aruba 2530 switch.
    Firmware
    I run Ansible 2.5.1 and python 2.7.17
    In Ansible changing the hostname with:
    arubaoss_system_attributes:
       hostname: "name"
    and creating a vlan via
    arubaoss_vlan:
      command: config_vlan
    works fine
    when itry to use
    arubaoss_routing:
       state: create
    i get an error. Error 404 Not Found. Connection Close {server": "eHTTP v2.0", "status": 404, "url": "http://172.31.254.160:80/rest/v7.0/ip-route/settings"}
    It seems something in REST API isnt working properly. But show rest-interface gives me:
    REST Interface : Enabled
    REST Operational Status : Up
    REST Session Idle Timeout : 600 seconds
    HTTP Access : Enabled
    HTTPS Access : Disabled
    Can someone please point me in the right direction?
    If extra info is required i would like to hear.
    Thanks in advance.
  • 2.  RE: Arubaos Ansible REST starting
    MVP GURU
    Posted Apr 03, 2020 04:29 AM
    Hi jangenent
    the 2530 is a L2 switch and it is not possible to have ip routing...
  • 3.  RE: Arubaos Ansible REST starting
    Posted Apr 03, 2020 07:09 AM
    Hi Alagoutte,
    You are right and indeed the 2530 is a L2 switch and it is not possible to have ip routing... That was a dumb thing to try. I forgot to mention that also other REST commands didnt work (example reboot, and i am sure the switch supports reboot haha).
    Anyway thanks for the list of different methods to use the switch. As i understand, most of the links you gave me are not specific for Ansible. They can general methods that you can use to configure a switch?
  • 4.  RE: Arubaos Ansible REST starting
    Posted Apr 23, 2020 03:48 PM
    Hi @jangenent !
    Here are some resources to get you started with automating with Ansible:
    If you're looking into using a combination of the REST API modules with the SSH/CLI modules I recommend looking at our README.md  that explains how to use both REST API and SSH/CLI modules.
    Please me let know if you're having any more trouble or have any more questions!
