ArubaOS AP-105 Upgrade Query
  • 1.  ArubaOS AP-105 Upgrade Query
    Posted Aug 04, 2017 10:34 AM
    I have inherited an Aruba VC wireless network based on AP-105 hardware. We have an Aruba S2500 PoE switch alongside the 15 AP-105 units.
    Name: Aruba Operating System Software
    Type: 105
    Build Time: 2017-02-22 01:10:03 PST
    Version: 6.4.4.8-4.2.4.6_58505
    Website: http://www.arubanetworks.com
    Is my Aruba wireless network as up-to-date as possible? Is there a new ArubaOS I should be running? How do I procure and upgrade to a new ArubaOS?
    Thanks in advance for any help.
    Perry Lund
    Evergreen Lutheran High School
  • 2.  RE: ArubaOS AP-105 Upgrade Query
    MVP EXPERT
    Posted Aug 04, 2017 10:56 AM
    Hey, the hardware you have is an Aruba Instant AP105, the latest available software release for this is 6.4.4.8-4.2.4.8.
    You can download the latest firmware from the below
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=25853
    Or from within the Virtual Controller (Maintenance -> Firmware)
  • 3.  RE: ArubaOS AP-105 Upgrade Query
    Posted Aug 04, 2017 11:05 AM
    I did try the firmware update from the VC and the message is there is no newer version. (see attached screen).
    I am interested in finding out if I can run ArubaOS 8.x on my system.
  • 4.  RE: ArubaOS AP-105 Upgrade Query
    MVP EXPERT
    Posted Aug 04, 2017 11:08 AM
    You will need to download this from the support site. ArubaOS 8 cannot be installed on the Aruba Instant product line.
  • 5.  RE: ArubaOS AP-105 Upgrade Query
    Posted Aug 04, 2017 11:18 AM
    Thank you for the information.
  • 6.  RE: ArubaOS AP-105 Upgrade Query
    Posted Aug 04, 2017 11:22 AM
    I did see on the Aruba site this info on ArubaOS 6.5
  • 7.  RE: ArubaOS AP-105 Upgrade Query
    MVP EXPERT
    Posted Aug 04, 2017 11:26 AM
    Yes, however unfortunately support for all 11n Access Points has been  dropped from the 6.5.x code so at the moment the IAP105 will run 6.4 versions of code.
  • 8.  RE: ArubaOS AP-105 Upgrade Query
    Posted Aug 06, 2017 03:23 AM
    Just to clarify, the AP-105 is still supported on all active AOS software versions. However, for Instant software, the IAP-105 has been "parked" on version 4.2.
