ArubaOS availability
  • 1.  ArubaOS availability
    Posted Feb 28, 2019 03:23 PM
    Would anyone know when versions 6.5.4.11, 8.3.0.6 or 8.4.0.1 will be available for download? When I go on the Aruba website under "Instant" the latest versions on Standard Release are 6.5.4.3 or 8.3.0.3. Thanks!
  • 2.  RE: ArubaOS availability
    Posted Mar 01, 2019 04:12 AM
    Lates version with fixes are:
    Aruba Instant 4.2.4.12, 6.5.4.11, 8.3.0.6
    8.4.0.1 will be available within the next days.
    You can download the other Software here:
    8.3.0.6 (Standard Release)
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/33481/Default.aspx
    6.5.4.11  (Conservative Release)
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/32735/Default.aspx
    4.2.4.12  (Standard Release)
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=32870
  • 3.  RE: ArubaOS availability
    Posted Mar 01, 2019 10:29 AM
    Thanks Cordless!
    I follow the links and it asks me to log in from a page with a "service contract missing" message. When I log in it then just has the links to the older versions. I'll try to log in and link our warranty or log a call with support on Monday.
    Harvie
  • 4.  RE: ArubaOS availability
    Posted Mar 08, 2019 09:45 AM
    You'll need to have a valid contract with Aruba. In case you have one have a tciket opened.
    In additoon, 6.5.4.12 is the latest and also available for download.
    I've been using this code on 2 locations with IAP335 for 2 weeks now without any issues.
  • 5.  RE: ArubaOS availability
    Posted Mar 08, 2019 09:55 AM
    Thanks Jer,
    We took out ArubaCare which is still current - I couldn't see where to register this, there doesn't seem to be a section on the Aruba pages and HPE doesn't recognise the contract number.
    Mix of IAP-325 and IAP-205 here. I can see a folder for 6.5.3.11 on Conservative Release without logging in, but only the release notes. I take it being linked to a contract gives the newer versions?
  • 6.  RE: ArubaOS availability
    Posted Mar 08, 2019 10:12 AM
    Hi Harvie, seems that you will need a valid contract to see the newer version although I wouldn't know why this difference is present.
    Reaching out to your local Aruba contact or Aruba partner helps you solving this as I don't beleive you will be able to add/change your contract details on your own.
  • 7.  RE: ArubaOS availability
    Posted Mar 15, 2019 06:47 AM
    6.5.4.11 now available on the public site for download as Conservative Release. Also 8.3.0.6 as Standard Release, but this doesn't have a Taurus version listed for IAP-205? Is this to be released later? We only put our 205s in a couple of years ago (almost 60 of them) and I'm concerned if future updates won't be made available, particularly security patches!
  • 8.  RE: ArubaOS availability
    Posted Mar 15, 2019 07:02 AM
    Harvie, 8.3.0.0 does not have support for the devices below according to the release notes.
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=30635
    The latest instant vulnerability is patched in 6.5.4.11, according to this page here:  https://www.arubanetworks.com/support-services/security-bulletins/ and there is a Taurus download for 6.5.4.11
  • 9.  RE: ArubaOS availability
    Posted Mar 15, 2019 07:38 AM
    Thanks CJoseph! Wasn't sure if it would be updated later. We'll update to 6.5.4.11 meantime.
