ArubaOS Built In Certificate renew
  • 1.  ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 06:11 PM
    hi,
    my Aruba Controller Built-in Certificate has expired in 11 auguest 2017, could any one tell me to witch version i should upgrade my controller to get a valid certifcate.
    Regards
  • 2.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 06:18 PM
    You should not be using the default certificate. You need to acquire your own
  • 3.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 06:45 PM
    Hi Cappali,
    thank you for the answer , i know that i do not have to use it, i need to use it , because my customer can't bay a public certificate.
    so could you tell to witch version I need to upgrade my Controller to get it, or not ?
    Regards
  • 4.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 06:49 PM
    You cannot use the default certificate in a production environment.
  • 5.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 08:08 PM
    Hi Cappali,
    I should not and i know the risks, now if you now a version of arubaos that it have a valid certificate tell me .
    and any way thanks for your advices.
  • 6.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 08:22 PM
    There is no valid certificate. They're self-signed and cannot be used.
  • 7.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 08:36 PM
    I'm talking about the built in certificate , i use to work with it  but it have expired in 11/08/2017.
    for the seconde time i know that i should not use a buit in , but  i need to use it.
  • 8.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 08:39 PM
    It was revoked last year. You need to provide your own certificate.
  • 9.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 09:35 PM
    cappalli
    i read your article
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
    do you have any tutorial to generate a cerificate with lets encrypt
  • 10.  RE: ArubaOS Built In Certificate renew
    Posted Sep 28, 2017 09:38 PM
    No. LetsEncrypt is not recommended as it requires a renewal every 90 days. You can get a standard certificate for around $4.99.
  • 11.  RE: ArubaOS Built In Certificate renew
  • 12.  RE: ArubaOS Built In Certificate renew
    Posted Feb 13, 2019 06:31 AM
    So upgrading the firmware is not resolving this, correct? The newer firmware versions are no longer bundled with a default certificate, is that it?
  • 13.  RE: ArubaOS Built In Certificate renew
    Posted Feb 13, 2019 12:14 PM
    The default certificate has been self-signed for over 2 years now.
