Internet of Things (IoT) and Industrial IoT (IIoT)
Forum to discuss the HPE Aruba Networking Edge Service Platform and all associated products and solutions for any type of IoT or IIoT application. Included are IoT technology partners (eg. EnOcean, Microsoft, and Zebra) and IIOT technology partners (eg. ABB and Siemens)
This thread has been viewed 19 times
  • 1.  ArubaOS-CX
    Posted Sep 08, 2022 08:14 AM
    I have been working with ArubaOS/ProVision for a while and I am just deploying my first ArubaOS-CX switch.
    In ArubaOS to untag VLAN 80 on port 1-24 I would do the commands below.
    config
    vlan 80
    untagged 1-24
    Can you set the access VLAN on multiple ports like this at once or does it have to be one at a time like this?
    config
    interface 1/1/1
    vlan access 80
    interface 1/1/2
    vlan access 80
    interface 1/1/3
    vlan access 80
    interface 1/1/4
    vlan access 80
    and so on.......
    Am I going about this the wrong way or missing something?
  • 2.  RE: ArubaOS-CX
    MVP GURU
    Posted Sep 08, 2022 10:20 AM
    Hi! I believe this is the wrong Forum's discussion section (IoT) to ask for ArubaOS-CX help (you risk your thread will pass unnoticed), better to eventually open this thread on the Wired Intelligent Edge section for better visibility.
    By the way, if your ArubaOS-CX version is enough recent (say newer than 10.03...and it should be that, newer than 10.05, at least) the command interface 1/1/1-1/1/4 should work projecting you into the config-if context for the indicated range (1/1/1-1/1/4), at that point you can specify the vlan access option for that range, example:
    cx# config
    cx(config)# interface 1/1/1-1/1/4
    cx(config-if-<1/1/1-1/1/4>)# vlan access
    <1-4094> VLAN identifier
    cx(config-if-<1/1/1-1/1/4>)# vlan access 20
    Give it a try!
  • 3.  RE: ArubaOS-CX
    Posted Sep 08, 2022 10:36 AM
    Thank you that is what I was looking to do.  I was going about it the wrong way.
    I will see if support can move or delete this ticket since it doesn't look like I can.
