Wired Intelligent Edge
last person joined: 7 hours ago
ArubaOS-CX_10_10_0002 copy to statup-config fails
This thread has been viewed 29 times
  • 1.  ArubaOS-CX_10_10_0002 copy to statup-config fails
    Posted Jun 26, 2022 06:31 AM
    Hi All,
    Testing the new version of the simulator, I observ my ztp solution using DHCP and TFTP fails.
    Testing manually with copy tftp://[ip]/sw01.conf startup-config vrf mgmt fails with:
    Copying configuration: [Failure]
    exit status 5
    When using copy - paste into the console the configuration comes in fine.
    Testet on VMware workstation 16.2.3, VMware ESXI 6.5 and EVE-NG Pro 5.0.1-17
    Anyone knowing where to lookup the exit status 5? Anyone got this working? Anyone tested it on hardware?
    This have been working fine on both 10.08 and 10.09.
    Arne Opdal
  • 2.  RE: ArubaOS-CX_10_10_0002 copy to statup-config fails
    Posted Oct 06, 2022 10:41 PM
    I am Facing the same issue, i am testing a configuration push with Ansible, got error 500 and the same exit status 5 when trying to copy the configuration from a remote tftp. On Ansible i recieve the error "GENERIC OPERATION ERROR: Error copying configuration. exit status 5\\n: Code: 500'\n" also tested with the new 10.10.1000 version same behaviour
    All works on version 10.09.0002.
