Wired Intelligent Edge
ArubaOS-CX 10.01: how to change/edit a NAE Agent's name once created?
  • 1.  ArubaOS-CX 10.01: how to change/edit a NAE Agent's name once created?
    MVP GURU
    Posted Sep 14, 2018 04:04 AM
    Hello, it seems it's not possible to edit a NAE Agent name once it is created (it doesn't matter if the Agent is enabled or disabled, no edit feature related to Agent's name appears)...as a workaround it looks like a NAE Agent must be deleted and recreated with the new desired name if a name change is required. Am I wrong?
  • 2.  RE: ArubaOS-CX 10.01: how to change/edit a NAE Agent's name once created?
    Posted Sep 18, 2018 04:35 AM
    Correct. Today, there is no way to edit the name of a deployed NAE agent.
  • 3.  RE: ArubaOS-CX 10.01: how to change/edit a NAE Agent's name once created?
    Posted Sep 20, 2018 12:02 PM
    Hi Parnassus,
    As Vincent mentioned, you are correct in that you are unable to edit an agent's name.  I want to add that while the workaround is to delete and re-add the agent from the script, when you delete the agent it is likely that you'll lose information that has already been collected, even though you're remaking the agent with a different name.
    Alvin
    Check out our new Developer Community for Scripting and Automation, here!
  • 4.  RE: ArubaOS-CX 10.01: how to change/edit a NAE Agent's name once created?
    MVP GURU
    Posted Sep 21, 2018 10:36 AM
    Thanks Giles and Alvin. Maybe in a near future - with NAE more and more development - it will be possible to simple edit the NAE Agent name.
