Wired Intelligent Edge
ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
This thread has been viewed 45 times
  • 1.  ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    MVP GURU
    Posted Aug 04, 2018 04:00 AM
    Hello all,
    Probably a very silly question: is actually possible to select, as example, a range of Interfaces (or a list of specific Interfaces) and execute a permitted command against that range/list?
    Specifically I want to change Interface Mode from Routed (Default) to Access and so I need to apply the no routing command to a range going from 1/1/1 to 1/1/47 on Aruba 8320...do I need to enter in each Interface Context and executre the no routing or can I select 1/1/1-1/1/47 and exectute the no routing command in one shot for them all?
    Maybe it is simpler than I think...and I'm for sure missing something (<IFRANGE> or <PORT-LIST> instead of <IFNAME> as command option? if so how - and when (with which commands) - the <IFRANGE>/<PORT-LIST> is supposed to work?)...or should I work with the alias command?
  • 2.  RE: ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    Posted Aug 07, 2018 03:08 PM
    Hi Parnasus,
    Today the interface rage is only available to apply access lists and policies:
      interface 1/1/3-1/1/6 apply access-list XYZ
    Regards, Ruben.-
  • 3.  RE: ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    MVP GURU
    Posted Aug 07, 2018 03:25 PM
    Hello Ruben, yeah...I noticed...that was my fear (I add that it seems that ports list can be passed as an option on some ip igmp snooping and show/clear mvrp statistics related commands).
    Is it on the roadmap to provide port-list as option on more - to me - common/recurring commands (interface/vlan related)?
    Davide.
  • 4.  RE: ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    Posted Aug 07, 2018 06:52 PM
    HI Davide,  Thank you for the feedback and understand the ask. We'll be looking to provide more range supporting commands in future software releases. Thanks!
  • 5.  RE: ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    Posted Jul 03, 2019 03:57 AM
    Just to make sure you got the information through the parnter webinar we organized. Range context is now supported for interfaces and VLANs in 10.3 release.
  • 6.  RE: ArubaOS-CX 10.01 (or 10.00): executing a command against a range of interfaces
    MVP GURU
    Posted Jul 03, 2019 05:24 AM
    Hi Giles, I've got! The upgrade to ArubaOS-CX 10.3 is going to be my very next task. Thank you.
