Wired Intelligent Edge
ArubaOS-CX 10.03.0071 is here!
  • 1.  ArubaOS-CX 10.03.0071 is here!
    MVP GURU
    Posted Jan 16, 2020 04:21 AM
    Hi all,
    ArubaOS-CX 10.03.0071 Software Images for Aruba 8400, Aruba 8325 and Aruba 8320 have just been published.
    References:
    Please refer to Release Notes provided on above links for a complete view of new features, enhancements and bug fixes introduced with this ArubaOS-CX software release.
    Note: the ArubaOS-CX 10.03.0071 was released to fix only the OSPF related ticket CR_66903 "The switch fails to correctly update certain OSPFv2 routes in the routing table".
  • 2.  RE: ArubaOS-CX 10.03.0071 is here!
    Posted Jan 17, 2020 12:26 PM
    Is it the same ArubaOS-CX on 6300/6400 too? So should we expect update for those in couple days?
  • 3.  RE: ArubaOS-CX 10.03.0071 is here!
    Posted Jan 17, 2020 01:20 PM
    The minimum version on 6300/6400 is 10.4.
    So these 10.03.0071 release  does trigger new 10.4 release which has it own cycle.
  • 4.  RE: ArubaOS-CX 10.03.0071 is here!
    Posted Jan 17, 2020 01:21 PM
    Ah true, my bad. I hope ArubaOS-CX doesn't follow the procurve line where you can go to HPE site and then have 10 different 16.xx to choose from, with different 16.xx.yyy's :)
  • 5.  RE: ArubaOS-CX 10.03.0071 is here!
    MVP GURU
    Posted Jan 17, 2020 04:31 PM
    Well...actually...ArubaOS-Switch has a maintenance branch (16.02) and three actively developed (features differentiated) newer branches (currently 16.10, 16.09 and 16.08)...with a release cycle where, at some point, each new branch is "forked" (read: generated) by previous branch...so what you should see is, on average, four branches receiving updates...but...you will also see more, reported as current (updated last time months ago).
