Wired Intelligent Edge
ArubaOS-CX 10.04.0030 is here!
  • 1.  ArubaOS-CX 10.04.0030 is here!
    MVP GURU
    Posted Feb 02, 2020 08:41 AM
    Hi all,
    ArubaOS-CX 10.04.0030 Software Images for Aruba 8400, Aruba 8325Aruba 8320, Aruba CX 6300 and Aruba CX 6400 Switch series have just been published.
    References:
    Please refer to Release Notes provided on above links for a complete view of new features, enhancements and bug fixes introduced with this ArubaOS-CX software release.
    29-01-2020: PAY ATTENTION Since the first appearance of ArubaOS-CX 10.04.0030 on ASP - during January 29th 2020 - all Release Notes links listed above shared the same URL directing to a temporary document stating that "The Release Notes for this Software will be available soon." (https://support.hpe.com/hpsc/doc/public/display?docId=a00078517en_us); so, despite software images are ready for download, ArubaOS-CX 10.04.0030 Relase Notes documents were not published yet (both on ASP and also on HPE Support web site).
    04-02-2020: Release Notes links were finally fixed.
  • 2.  RE: ArubaOS-CX 10.04.0030 is here!
    MVP GURU
    Posted Feb 06, 2020 02:58 PM
    Thanks for update about release ;-)
    there is a also NetEdit 2.0.2...
  • 3.  RE: ArubaOS-CX 10.04.0030 is here!
    MVP GURU
    Posted Feb 07, 2020 02:33 AM
    Yeah...but I didn't mention about that because no Release Notes was available (despite that - without any fear - I promplty updated my Aruba NetEdit 2.0.1 to 2.0.2 as the software was de-facto available).
    Still today Aruba NetEdit 2.0.2 Release Notes links to a temporary document (as initially happened for ArubaOS-CX 10.04.0030's Release Notes between 29/01 and 04/02).
  • 4.  RE: ArubaOS-CX 10.04.0030 is here!
    Posted Feb 11, 2020 09:13 AM
    Thanks for the info !!
    From the 10.04.0030 RELEASE NOTES:
    "ConfigCR_72205
    Symptom: The switch configuration is not saved.
    Scenario: After issuing the write memory command and then removing power from the switch, the switch configuration may not be saved properly.
    Workaround: Use the sync command prior to removing power from the switch."
    Excuse my ignorance...I cannot find the context for the SYNC command referenced in the 10.04.0030 release notes.  I have had the "not saved" problem.
    Thanks in advance.
  • 5.  RE: ArubaOS-CX 10.04.0030 is here!
    Posted Feb 11, 2020 10:01 AM
    Let me clarify.
  • 6.  RE: ArubaOS-CX 10.04.0030 is here!
    Posted Feb 11, 2020 10:17 AM
    The workaround is to use: start-shell
    then use the sync linux command:
    https://en.wikipedia.org/wiki/Sync_(Unix)
    to flush  disk buffers on disk.
    Sorry for the missing context in the release note.
