Wired Intelligent Edge
  • 1.  ArubaOS-CX 10.05.0021: strange "Cannot assign requested address" when trying to copy running config via TFTP using an FQDN.
    Posted Nov 20, 2020 08:09 AM
    Edited by parnassus Nov 20, 2020 08:27 AM
    Aruba 8320 recently upgraded to 10.05.0021 from 10.03.0090.
    Error on copy running configuration to TFTP Server when using FQDN: curl: (45) bind failed with errno 99: Cannot assign requested address.
    NO error if the copy to TFTP Server is executed using the IP address.
    Before the update both methods (FQDN and IP) worked.
    The same command executed pre/post upgrade:
    Pre (10.03.0090):
    vsx-1# copy running-configuration tftp://nas01.datafarm.local/aruba-8320-vsx-1-running-config-cli-10.03.0090-pre-upgrade cli vrf mgmt
      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                     Dload  Upload   Total   Spent    Left  Speed
    100 19614    0     0  100 19614      0  6302k --:--:-- --:--:-- --:--:-- 6302k
    100 19614    0     0  100 19614      0  5952k --:--:-- --:--:-- --:--:-- 5952k
    Copying configuration: [Success]​
    Post (10.05.0021):
    vsx-1(config)# copy running-config tftp://nas01.datafarm.local/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade cli vrf mgmt
    Copying configuration: [Failure]
    error uploading running-config
    vsx-1(config)# copy running-config tftp://10.255.0.250/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade cli vrf mgmt
    100 19189    0     0  100 19189      0   500k --:--:-- --:--:-- --:--:--  500k
    100 19189    0     0  100 19189      0   495k --:--:-- --:--:-- --:--:--  495k
    Note: OoBM interface should run a 1Gbps. Our TFTP server is connected with 4x1Gbps LACP.
    Difference in upload speeds are due to the fact that on the case of copy to TFTP performed on ArubaOS-CX 10.05.0021 our NAS was heavily used so the free bandwidth was somewhat limited.
    Nevertheless the upload happened successfully in both cases (on 10.03.0090 by using our nas01's FQDN and on 10.05.0021 only by using our nas01's IP).
    Our internal NS(s) were always reachable since, in both cases (pre/post-upgrade) simple ping using both IP or FQDN worked:
    Pre (10.03.0090):
    vsx-1# ping 10.255.0.250 vrf mgmt
    PING 10.255.0.250 (10.255.0.250) 100(128) bytes of data.
    108 bytes from 10.255.0.250: icmp_seq=1 ttl=63 time=0.105 ms
    108 bytes from 10.255.0.250: icmp_seq=2 ttl=63 time=0.112 ms
    108 bytes from 10.255.0.250: icmp_seq=3 ttl=63 time=0.119 ms
    108 bytes from 10.255.0.250: icmp_seq=4 ttl=63 time=0.105 ms
    108 bytes from 10.255.0.250: icmp_seq=5 ttl=63 time=0.118 ms
    --- 10.255.0.250 ping statistics ---
    5 packets transmitted, 5 received, 0% packet loss, time 4087ms
    rtt min/avg/max/mdev = 0.105/0.111/0.119/0.014 ms
    PING nas01.datafarm.local (10.255.0.250) 100(128) bytes of data.
    108 bytes from 10.255.0.250: icmp_seq=1 ttl=63 time=0.101 ms
    108 bytes from 10.255.0.250: icmp_seq=2 ttl=63 time=0.104 ms
    108 bytes from 10.255.0.250: icmp_seq=3 ttl=63 time=0.129 ms
    108 bytes from 10.255.0.250: icmp_seq=4 ttl=63 time=0.125 ms
    108 bytes from 10.255.0.250: icmp_seq=5 ttl=63 time=0.117 ms
    --- nas01.datafarm.local ping statistics ---
    5 packets transmitted, 5 received, 0% packet loss, time 4093ms
    rtt min/avg/max/mdev = 0.101/0.115/0.129/0.013 ms​
    to prove that name resolution worked pre-upgrade and, see below, also post-upgrade.
    Post (10.05.0021):
    108 bytes from 10.255.0.250: icmp_seq=1 ttl=63 time=4.16 ms
    108 bytes from 10.255.0.250: icmp_seq=2 ttl=63 time=2.82 ms
    108 bytes from 10.255.0.250: icmp_seq=3 ttl=63 time=1.65 ms
    108 bytes from 10.255.0.250: icmp_seq=4 ttl=63 time=1.14 ms
    108 bytes from 10.255.0.250: icmp_seq=5 ttl=63 time=0.392 ms
    5 packets transmitted, 5 received, 0% packet loss, time 4003ms
    rtt min/avg/max/mdev = 0.392/2.035/4.160/1.325 ms
    vsx-1# ping nas01.datafarm.local vrf mgmt
    108 bytes from 10.255.0.250: icmp_seq=1 ttl=63 time=2.56 ms
    108 bytes from 10.255.0.250: icmp_seq=2 ttl=63 time=4.19 ms
    108 bytes from 10.255.0.250: icmp_seq=3 ttl=63 time=2.12 ms
    108 bytes from 10.255.0.250: icmp_seq=4 ttl=63 time=0.412 ms
    108 bytes from 10.255.0.250: icmp_seq=5 ttl=63 time=1.45 ms
    5 packets transmitted, 5 received, 0% packet loss, time 4056ms
    rtt min/avg/max/mdev = 0.412/2.151/4.199/1.255 ms
    Note that the average RTT measured when our VSX was on 10.05.0021 with respect to the average RTT of the same ping made when the VSX was on 10.03.0090 was higher due to the NAS01 usage at that time.
    I retried few times and the the ping's RTT lowered on 10.05.0021 (being basically equal to RTT seen before the upgrade...notice that the upgrade happened hours before copy test to TFTP once in 10.05.0021) but the issue about copy to TFTP by using FQDN persisted.
    Cleary our TFTP service running on our NAS01 didn't changed in between.
    Reversed output of show events (related to copy attempts to TFTP Server):
    2020-11-20T12:46:28.213335+01:00 vsx-1 hpe-config[6141]: Event|6801|LOG_INFO|AMM|-|Copying configs from: running-config to: URL: tftp://10.255.0.250/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade, in format: cli, using vrf: mgmt
    2020-11-20T12:45:58.678713+01:00 vsx-1 hpe-config[6057]: Event|6802|LOG_ERR|AMM|-|Error while copying configs. Error: error in remote file transfer
    2020-11-20T12:45:58.451339+01:00 vsx-1 hpe-config[6057]: Event|6801|LOG_INFO|AMM|-|Copying configs from: running-config to: URL: tftp://nas01.datafarm.local/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade, in format: cli, using vrf: mgmt
    2020-11-20T12:44:14.551064+01:00 vsx-1 hpe-config[5785]: Event|6802|LOG_ERR|AMM|-|Error while copying configs. Error: error in remote file transfer
    2020-11-20T12:44:14.319726+01:00 vsx-1 hpe-config[5785]: Event|6801|LOG_INFO|AMM|-|Copying configs from: running-config to: URL: tftp://nas01.datafarm.local/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade, in format: cli, using vrf: mgmt
    2020-11-20T12:43:38.746978+01:00 vsx-1 hpe-config[5677]: Event|6802|LOG_ERR|AMM|-|Error while copying configs. Error: error in remote file transfer
    2020-11-20T12:43:38.522513+01:00 vsx-1 hpe-config[5677]: Event|6801|LOG_INFO|AMM|-|Copying configs from: running-config to: URL: tftp://nas01.datafarm.local/aruba-8320-vsx-1-running-config-cli-10.05.0021-post-upgrade, in format: cli, using vrf: mgmt
    The same happens on the other Aruba 8320 (VSX Secondary node, vsx-2).
    OoBM interfaces were/are clearly connected at 1000FDx to our LAN infrastructure.
    Side Note: the copy support-files all tftp://nas01.datafarm.local/support-file.tar.gz vrf mgmt command, as example, works flawlessly even with FQDN, as expected!
    Davide Poletto
  • 2.  RE: ArubaOS-CX 10.05.0021: strange "Cannot assign requested address" when trying to copy running config via TFTP using an FQDN.
    Posted Nov 20, 2020 02:02 PM
    I would recommend to open a case to support.
    Vincent Giles
  • 3.  RE: ArubaOS-CX 10.05.0021: strange "Cannot assign requested address" when trying to copy running config via TFTP using an FQDN.
    Posted Nov 20, 2020 07:26 PM
    Edited by parnassus Nov 20, 2020 07:26 PM
    Thanks Vincent, support case opened (Case 5351719813).
    Davide Poletto
  • 4.  RE: ArubaOS-CX 10.05.0021: strange "Cannot assign requested address" when trying to copy running config via TFTP using an FQDN.
    Posted Mar 21, 2025 04:10 AM
    Your "ip source-interface" in your config might have the wrong ip.
  • 5.  RE: ArubaOS-CX 10.05.0021: strange "Cannot assign requested address" when trying to copy running config via TFTP using an FQDN.
    Posted Mar 21, 2025 06:23 AM
    Edited by parnassus Mar 21, 2025 06:48 AM
    Hello, to be honest I had hard time in resurrecting what was wrong about an issue noticed almost 5 years ago but, nevertheless, our VSX hadn't and hasn't any "ip source-interface" option explicitly set into its running-configuration so for sure it wasn't the culprit.
    I recall now we did the AOS-CX upgrade from AOS-CX 10.05.0021 to ArubaOS-CX 10.07.0050 on December 2021 and simply that fixed the issue (or glitch as we called it) and I can confirm that, since then, it worked flawlessly.
    Even today that our VSX is running on AOS-CX 10.13 the copy to the TFTP server works either with IP or with FQDN (tested both copying to IP and to FQDN of our unchanged TFTP server).
    Cheers, Davide.
