I spoke to our responsible Aruba SE as well and he told me that this is an error in the CLI administration guides! So as you said, the configuration of a Loopback Interace as well as a secondary IP-Address on an SVI is not supported on the ArubaCX 6000 and 6100 models!
Original Message:
Sent: Nov 20, 2023 07:14 PM
Subject: ArubaOS-CX 6100 - Loopback Interface and SVI secondary IP missing?
try the CLI and see if the command "ip address <ip addr/mask> secondary" exists
Original Message:
Sent: Nov 19, 2023 02:00 AM
do you also know, if the same applies to the ‚secondary IP-Address' configuration option on a SVI?
Original Message:
Sent: 11/18/2023 7:37:00 PM
Subject: RE: ArubaOS-CX 6100 - Loopback Interface and SVI secondary IP missing?
it is definitely not supported. Check the IP routing user guide
Original Message:
Sent: Nov 18, 2023 02:53 AM
I thinks so too! it looks that both configuration options (loopback interface and secondary IP-Address) are not available, altough they should be at least according the CLI configuration guides - e.g. for release 10.09...
https://www.arubanetworks.com/techdocs/AOS-CX/10.09/PDF/cli_6000-6100.pdf (=> page 544)
hm, not sure but maybe I misunderstood this section in the guide or I'd missed something other relevant
Original Message:
Sent: 11/17/2023 6:03:00 PM
firmware 10.6.x is end of support, it is best to use 10.10.x or later.
loopback interfaces are not supported in 6100 CX switches.
Original Message:
Sent: Nov 17, 2023 04:46 AM
I´ve installed an ArubaOS-CX 6100 (JL675A) /w Version: PL.10.06.0110 and I´m wondering that there is no possibilty to configure either a Loopback Interface nor a secondary IP-Address on a SVI?
Regarding the Config Guide for 10.06 this should be possible or I´m understanding something wrong?!
thank you for all kind of feedback/information!
