Wired Intelligent Edge
ArubaOS-CX 8320 VLAN ID 4094
  • 1.  ArubaOS-CX 8320 VLAN ID 4094
    Posted Nov 29, 2018 08:06 AM
    I'm trying to understand why the 8320 doesn't let me use the ID 4094.
    As per docs, pg 21 Aruba 8320 Layer 2 Bridging Guide for ArubaOS-CX 10.01 just the IDs VLAN 1-4040 are avaliable.
    Version : TL.10.00.0008
    Build Date : 2018-02-15 11:00:41 PST
    Build ID : ArubaOS-CX:TL.10.00.0008:4d4e3b0caef5:201802151853
    Build SHA : 4d4e3b0caef546ab5e2b6a4e4c99e8947b55fdff
    Active Image : secondary
    We have the ID 4094 as the management VLAN. The old 5500 use this ID for management.
    Is there any workaroud?
  • 2.  RE: ArubaOS-CX 8320 VLAN ID 4094
    MVP GURU
    Posted Nov 29, 2018 09:59 AM
    Interesting, it looks like the admitted range is really 1-4040...I noticed that the creation of any VLAN from 4041 to 4094 is not permitted (is the range 4041-4094 internally reserved?) providing the message you saw "Ignoring the operation on internal VLAN(s) x" where x is any VLAN between 4041 included and 4094 included.
  • 3.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Nov 29, 2018 10:58 AM
    So, you beleve that I cannot use the 4094 for management VLAN?
    There are quite a few switch using the 4094 as management VLAN. Is there any workaround?
  • 4.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Nov 29, 2018 11:29 AM
    Yes, this is correct.
    On 8320: 1-4040 can be used for VLAN. 4041-4094 are reserved VLANs and can't be used for any purpose than what they are reserved for.
    On 8400: 1-4094 can be used. Reserved VLANs are in a separate range (8000~, you may see that range using the API to list the VLANs).
    This is no workaround to use 4094 on 8320.
    Vincent
  • 5.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Nov 29, 2018 11:37 AM
    Interesting that we can't find any information for what reason there are reserved VLANs on 8340.
    The next test I'm going to do is to check if it can a least "pass the tag" to a trunk port from one switch to another.
  • 6.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Nov 29, 2018 12:31 PM
    Just to let you know.
    It doesn't pass any traffic on 4094.
  • 7.  RE: ArubaOS-CX 8320 VLAN ID 4094
    MVP GURU
    Posted Nov 29, 2018 12:48 PM
    @vincent.giles wrote: On 8320: 1-4040 can be used for VLAN. 4041-4094 are reserved VLANs and can't be used for any purpose than what they are reserved for.
    Hello Vincent, that's interesting...just curious, a question: why then on Aruba 8320 the show capacities vlan-count CLI Command (which is supposed to show the maximum number of VLANs supported in the system) still outputs 4094?
  • 8.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Dec 03, 2018 05:39 PM
    This is because they are used internally. That being said, it is good feedback and there is on-going CLI improvment to get better clarity.
    Vincent
  • 9.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Jun 30, 2020 03:00 AM
    There will be an update on this thread for reserved-vlan in a couple of weeks.
  • 10.  RE: ArubaOS-CX 8320 VLAN ID 4094
    Posted Sep 17, 2020 10:01 AM
    In 10.5, internal VLANs range is now configurable.
  • 11.  RE: ArubaOS-CX 8320 VLAN ID 4094
    MVP GURU
    Posted Sep 19, 2020 09:03 AM
    To be extremely clear:
    ArubaOS-CX 10.5, in comparison to previous versions, permits to modify the default VLAN IDs range (4041-4094, 54 continuous IDs) internally used by Aruba 8320 switch in order to be able to reuse exactly those VLAN IDs.
    Internally reserved VLAN IDs' range - made of 54 VLAN IDs - can't be "avoided" on Aruba 8320: it's mandatory.
    Does relocation need to be, like-for-like, by selecting another continuous range of 54 VLAN IDs or the range should be extended/shrank due to particular consideration related to route-only/LAG ports? say example 1000-1053 instead of 4041-4094?
    ArubaOS-CX 10.5 CLI manual specifies only that "The reserved range must be between 2 and 4094 and cannot exceed 256 VLANs. Default: 4041-4094." but also it warns "If the number of internal VLANs is less than the number of route-only ports and LAGs, some ports will be blocked and unable to be used." at the point that setting the range to be none (with the system internal-vlan-range none command) that warning become an explicit "All route-only ports and LAGs will be blocked.".
    I'm guessing If a particular Aruba 8320 scenario hasn't any route-only ports or any LAGs (apart of having VSX LAGs!)...can the internal-vlan-range be safely disabled with the above command? or the reference about LAG includes VSX LAG?
