Wired Intelligent Edge
ArubaOS-CX can't delete "public" snmp community
This thread has been viewed 56 times
  • 1.  ArubaOS-CX can't delete "public" snmp community
    Posted Feb 14, 2020 03:12 AM
    By default the Aruba8320 uses the public community string. I configured a string called "private", and according to documentation, the public community should be removed automatically. However, that is not the case. When I try to remove the community manually, an error is returned:
    switch(config)# no snmp-server community public
    Community 'public' can't be deleted, as it is linked with another configuration.
    This is the current snmp config:
    switch# sh run | i snmp
    snmp-server vrf default
    snmp-server community private
    snmp-server host x.x.x.x trap version v2c community private
    switch# sh snmp comm
    SNMP communities
    private
    public
    Any ideas on how to remove the public community?
  • 2.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Feb 14, 2020 04:17 AM
    Short test I made:
    8320-3(config)# sh ru | inc snmp
    snmp-server vrf mgmt
    snmp-server system-description Lab 8320-3
    snmp-server system-location Grenoble
    snmp-server system-contact Vincent Giles
    snmp-server community ArubA
    vsx-sync aaa dhcp-server dns mclag-interfaces sflow-global snmp ssh time vsx-global
    8320-3(config)# no snmp-server community public
    You may try removing all other SNMP commands and then try again.
  • 3.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Feb 14, 2020 04:44 AM
    Removed all the snmp config so the snmp agent got disabled, but unfortunatly I still can't remove the public community. The switch keeps returning the same error message.
    I am running code TL.10.02.0010
  • 4.  RE: ArubaOS-CX can't delete "public" snmp community
    MVP GURU
    Posted Feb 17, 2020 10:40 AM
    May be good to update (to last 10.02 or 10.03....)
  • 5.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Aug 26, 2020 05:04 AM
    I don't understand this behavior of the SNMP configuration. When I try to delete the public community I get the following error message:
    I mean this makes sense, because the snmpv3 user is in use by this community:
    (config)# show snmpv3 context
    Name                         vrf                          Community
    operatorauth                 default                      public
    But I don't want to create another community, because then this community is available again via SNMPv2 without a password, I just want to disable the context to community relation completely, but without it my SNMPv3 user is not working. Can someone shed some light on this behavior?
  • 6.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Sep 30, 2020 08:58 PM
    Had the same issue when I needed to use a tool that only worked with SNMPv2. I added the SNMP-SERVER COMMUNITY PUBLIC command, ran my tool, got what I needed, then went and tried to remove the PUBLIC community:
    MyHost#no snmp-server community public
    I then remember seeing the word "public" somewhere, found it in "context" (as you showed in yours under SNMPv3). So I then thought to do the following:
    MyHost# sh snmpv3 context
    Name vrf Community
    SNMPV3-Context default public
    MyHost# config t
    MyHost(config)# no snmpv3 context SNMPV3-Context vrf default
    MyHost(config)# no snmp-server community public
    MyHost(config)# snmpv3 context SNMPV3-Context vrf default
    MyHost(config)# end
    PUBLIC Community removed. All back to normal.
  • 7.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Oct 01, 2020 06:32 AM
    Well then do a "show snmp community" and post an output here, would be surprised if there is no public community..
  • 8.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Oct 19, 2020 02:42 PM
    Just create a random snmp community and it will replace the default 'public'
    eg.
    SWITCH# show snmp community
    SNMP communities
    public
    SWITCH# conf t
    SWITCH(config)# snmp-server community XXXXX
    SWITCH(config)# ^Z
    SNMP communities
    XXXXXX
    SWITCH#
    ps. obviously don't use this community string
  • 9.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Mar 29, 2021 07:05 PM
    Am I reading into this thread correctly: If I want to use SNMPv3 I will necessarily have to have a SNMPv2 community of some name?
    What I want is SNMPv3 only - can this be done? We're failing a key PCI requirement by having SNMPv2 enabled on a device in the payment flow.
    --Matthew
    If I have in some way helped, please click the KUDOS button
  • 10.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Nov 03, 2021 08:04 AM
    Same situation here. We need to have snmpv3 running without an snmpv2 community. Any Updates on this issue
    Jay R
  • 11.  RE: ArubaOS-CX can't delete "public" snmp community
    Posted Nov 04, 2021 04:05 AM
    Please look at Aruba CX Switches - Disable SNMP v1 and v2 | Network Management (arubanetworks.com)
    Update to aruba cx 10.07
    and configure:  snmp-server snmpv3-only
    Robert Großmann
