Wired Intelligent Edge
ArubaOS-CX DUR with named VLANS
  • 1.  ArubaOS-CX DUR with named VLANS
    Posted Aug 05, 2020 05:17 AM
    Hi all,
    Is it possible with Clearpass to send named VLAN's back to the ArubaOX-CX (6200 switch) with a DUR. Or do i need a different method to achieve this?
    I dont see the option when i am trying to configure the role (see screenshot).
    Thanks in advance
  • 2.  RE: ArubaOS-CX DUR with named VLANS
    Posted Aug 05, 2020 03:58 PM
    It's supported in the Switch CLI:
    switch(config-pa-role)# vlan access
    <1-4094> VLAN identifier.
    name configure the VLAN name.
    You'll need to use the "advanced" option when creating the Enforcement Profile and enter the role via commands rather than the Standard UI.  We're looking into getting that updated in ClearPass.
     Make sure you're running the latest CX build - 10.05.0001+
  • 3.  RE: ArubaOS-CX DUR with named VLANS
    Posted Aug 11, 2020 05:05 AM
    Had to fix some more things (clearpass communication was not established correctly). But your suggestion did the trick
