Wired Intelligent Edge
ArubaOS-CX ESXi Installation not working
  • 1.  ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 04, 2020 01:54 PM
    I have installed the OVA a few different ways, added more resources, tried different network adapter settings, but the switch does not want to start up. See attached image for the console output. Does anyone know if I'm doing something wrong on the OVA deployment into my ESXi 6.0.0 Build 5572656 environment?
    Thanks!
  • 2.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 04, 2020 03:59 PM
    Hi Dustin, what ArubaOS-CX OVA image are you referring to exactly? ...kind of AOS-CX 10.04.0001 or AOS-CX 10.03.0020?
  • 3.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 04, 2020 05:42 PM
    I have tried AOS-CX 10.04.0001 and AOS-CX 10.02.0010. Both had the same results.
  • 4.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 05, 2020 09:26 AM
    FYI, I upgraded my ESXi host to 6.5 Update 1 and I still get the same results. See attached screenshots for the steps I take to deploy. vSwitch security policy also attached
  • 5.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 06, 2020 01:28 AM
    Do you have attach a serial port ?
    Work for me with a vCenter (and ESXi) and also virtualbox (on a windows laptop)
  • 6.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 06, 2020 07:22 AM
    I have not configured a serial interface. Is this needed?
  • 7.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 06, 2020 07:41 AM
    No
  • 8.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 06, 2020 12:30 PM
    I tried adding the serial port before the first boot, but it still gave the same errors. Another thing to note too, is if I restart the VM after these errors, this is all that I get on all subsequent boots:
  • 9.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 09, 2020 04:15 AM
    What release of ESXI ? on what plaform ? (Intel ? amd ?)
  • 10.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 09, 2020 07:16 PM
    ESXi version: 6.5.0
    ESXi build number: 5969303
    Running on:
    ProLiant DL360 G7
    8 CPUs x Intel(R) Xeon(R) CPU E5506 @ 2.13GHz
  • 11.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 12, 2020 02:35 PM
    Bump ^^
  • 12.  RE: ArubaOS-CX ESXi Installation not working
    MVP GURU
    Posted Mar 13, 2020 04:05 AM
    Sorry, no idea...
  • 13.  RE: ArubaOS-CX ESXi Installation not working
    Posted Mar 20, 2020 02:24 PM
    Sorry being late answering. Please try setting the correct date/time on your ESXi host. It should solve the issue.
  • 14.  RE: ArubaOS-CX ESXi Installation not working
    Posted Mar 24, 2020 05:14 PM
    Did that solve the issue ?
  • 15.  RE: ArubaOS-CX ESXi Installation not working
    Posted Aug 24, 2020 11:58 PM
    I'm having this same issue.  No matter how I change up the settings, the VM just keeps recycling.  I have tried setting the time on my esxi server as well, but this had no discerning affect.  Any other possible ideas?
  • 16.  RE: ArubaOS-CX ESXi Installation not working
    Posted Aug 25, 2020 04:30 PM
    Scrap this VM and re-install a fresh one with 10.04.3000 OVA.
    Have you tried on an other server ?
