Wired Intelligent Edge
ArubaOS CX Firmware Bug CR# AOSCX-148228
This thread has been viewed 66 times
  • 1.  ArubaOS CX Firmware Bug CR# AOSCX-148228
    Posted Jan 19, 2021 12:01 AM
    TAC advised me of ArubaOS CX Firmware Bug CR# AOSCX-148228. Is there a way to track this bug? Is there a way to share the bug info with others? Is there something like Cisco Bug Tracker?
    colan haisell
  • 2.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    MVP GURU
    Posted Jan 19, 2021 02:18 AM
    Hi Colan!
    "Is there something like Cisco Bug Tracker?"
    There is, you bet! ...but it's clearly not publicly exposed to us (I believe it's an internal tool).
    By the way, it would be helpful to know what ArubaOS-CX software release are you (or TAC was) referring to (e.g. 10.4, 10.5 or 10.6) in order to understand if that bug id was (eventually) already fixed or not.
    Davide Poletto
  • 3.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    Posted Jan 19, 2021 04:07 AM
    Known issues and fixed bugs are tracked in the release notes. In the Issues & Workarounds, and the Fixes section there is a Bug ID column and a description of the issue.
    If you need to get the status on a specific issue, you can reach out to TAC and ask for more information and timelines for resolution.
  • 4.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    MVP GURU
    Posted Jan 19, 2021 07:34 AM
    The 148228, if correct, looks quite high as Bug ID.
    Browsing various ArubaOS-CX Release Notes I never saw a Bug ID going that high (higher than say 99000): if I'm not wrong, all Bug IDs referenced on published Release Notes are unique and their IDs grow continuously within and across AOS-CX releases (no matter the platforms) - 10.0 -> 10.1 -> 10.2 -> 10.3 -> 10.4 -> 10.5 -> 10.6 - this made me to believe it's not a Release Notes's typical Bug ID.
    Davide Poletto
  • 5.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    Posted Jan 20, 2021 05:18 AM
    Davide,
    This ID is an internal tracking ID, not related to bug-ID number available in release-notes.
    To go back to the issue, this problem  is duplicated and verification in progress. Please contact TAC for more info.
    Vincent Giles
  • 6.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    MVP GURU
    Posted Jan 20, 2021 08:10 AM
    Hi Vincent! Exactly! I was just commenting what @Herman Robers​ wrote about Bug IDs available on Release Notes...
    Davide Poletto
  • 7.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    Posted Jan 27, 2021 04:37 PM
    Thanks everyone. It is insightful to know these details.
    colan haisell
  • 8.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    Posted Mar 23, 2021 11:42 PM
    This has been resolved in a recent firmware patch 10.06.0100
    Jayson Radford
  • 9.  RE: ArubaOS CX Firmware Bug CR# AOSCX-148228
    The bug referenced has now been resolved in AOS-CX 10.06.0100
    Jayson Radford
