Wired Intelligent Edge
ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
  • 1.  ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
    MVP GURU
    Posted Aug 16, 2019 08:40 PM
    Greetings, suddenly one port of an VSX LAG equipped with a SFP+ SR Transceiver J9150D went down (it was a flip-flop then definitely down), Transceiver diagnostic shows Tx Low Power related warnings:
    What conclusion can we gather about such diagnostic reports? SFP+ Transceiver temperature is few Celsius degrees higher than the average of all the others...and the issue seems to be only on trasmitting side...thanks for any insight you can provide!
  • 2.  RE: ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
    MVP GURU
    Posted Aug 19, 2019 03:47 AM
    Try to replace ? (with a another ?)
  • 3.  RE: ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
    MVP GURU
    Posted Aug 19, 2019 04:16 AM
    Hi Alexis, sure I'm going to try and replace the SFP+ Transceiver on the Aruba 8320 side (clearly we have spare) but I asked that to understand if it is possible to infer some other information from diagnostic to see where the fault could be.
  • 4.  RE: ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
    MVP GURU
    Posted Sep 02, 2019 03:22 AM
    Replaced with a spare (same SKU J9150D) and issue disappeared immediately. Open a case on ASP to request RMA.
