Wired Intelligent Edge
ArubaOS-CX Mobile App template issue
  • 1.  ArubaOS-CX Mobile App template issue
    Posted Jan 08, 2020 02:28 PM
    I'm testing the initial setup of a 6300M switch using the ArubaCX Mobile app. I tried creating a custom template file and importing to the switch from the app and everything goes well except for the spanning tree portion on the template. I want to setup rapid-pvst on the switch so I added these lines to my template:
    spanning-tree mode rpvst
    spanning-tree vlan 100,110,120,130,140
    But I get a Template failed validation saying that I cannot configure rpvst mode because I need to disable spanning-tree first to change the mode (see attachement for error).
    Is this an expected behavior? and is there a way to override this so I can change the stp mode during my initial setup? I did a workaround where I removed those lines from my custom template and then I do the setup stp manually but this kinda of breaks the magic of doing the initial configs using the app.
    Note: I also had errors when trying to setup the banner motd and banner execs using the app.
  • 2.  RE: ArubaOS-CX Mobile App template issue
    Posted Jan 13, 2020 05:32 PM
    what firmware version are you running on 6300s?
    ensure it is 10.04.0020.
    regards
  • 3.  RE: ArubaOS-CX Mobile App template issue
    Posted Jan 15, 2020 09:11 PM
    Hi Ariya, that's correct, I'm running the latest version.
  • 4.  RE: ArubaOS-CX Mobile App template issue
    Posted Jan 16, 2020 02:13 PM
    We are looking at it.
  • 5.  RE: ArubaOS-CX Mobile App template issue
    MVP GURU
    Posted Jan 21, 2020 04:23 AM
  • 6.  RE: ArubaOS-CX Mobile App template issue
    Posted Feb 14, 2020 03:28 AM
    This should be fixed within one month with a new AOS-CX release.
