Wired Intelligent Edge
ArubaOS-CX on GNS3! Connectivity problems!!!
This thread has been viewed 36 times
  • 1.  ArubaOS-CX on GNS3! Connectivity problems!!!
    Posted Sep 13, 2019 12:40 PM
    hello to all!!
    I´m tryng to work with GNS3 and ArubaOS-CX in order to lear how it works! After facing some problems with GNS3 and OS-CX I'm enabled to turn on some switches (virtually on gns3).
    I made a simple conection beetwen them (L2 or/and L3), links looks up and green state beetween  them.
    from CLI of both switches all ports are up/up...
    but.. there is no connectivity beetween them, no ping and no mac address´s descovery.
    maybe there is miss configuration some configuration form vmware or GNS3.
    Do you guys was faced this issue?
  • 2.  RE: ArubaOS-CX on GNS3! Connectivity problems!!!
    MVP GURU
    Posted Sep 15, 2019 05:00 AM
    Do you have look GNS3 Setup from https://afp.arubanetworks.com/afp/index.php/AOS-CX_OVA ?
  • 3.  RE: ArubaOS-CX on GNS3! Connectivity problems!!!
    Posted Sep 16, 2019 04:52 AM
    The CX simulator has some limitations that are listed in ASP
    (https://afp.arubanetworks.com/afp/index.php/AOS-CX_OVA )
    One of these limitations is that the port state is not reflected to the CLI. If you enable a port in CLI, whatever is the GNS3 connectivity, it will always stay up (until you shutdown the interface in CLI).
