We tested the OVA version of "ArubaOS-CX" registered in the "ASP Portal".
Here we configure the virtual switch in a looping structure like a triangular structure or a ring structure,
We activated the spanning tree on all switches.
Spanning Tree status is normally indicated by forwarding and blocking.
However, after entering the IP address on the Vlan interface of each switch.
The CPU usage of the "simple_switch" daemon on each switch 90%~150%.
This is the same symptom in the OVA image of the recently posted version 10.03.
