Wired Intelligent Edge
ArubaOS-CX Switches - Configuring for initial access and performing a software upgrade
This thread has been viewed 258 times
  • 1.  ArubaOS-CX Switches - Configuring for initial access and performing a software upgrade
    Posted Apr 11, 2019 09:59 AM
    In this post, I have used the Aruba 8320 Switch, which has 48 SFP+ 10GbE ports and 6 QSPF+ 40GbE ports.
    We will looking on how to configure this ArubaOS-CX switch for initial access and perform a software upgrade.
    Console Access:
    The speed of the serial link must be set to 115200 bits per second, in order to get console access to the switch.
    The default username is admin with no password set.
    Getting the Out-of-band management interface UP:
    The below commands will turn on the Out-of-band interface to UP state and get the IP address from the DHCP Server.
    8320#
    8320# configure terminal
    8320(config)# interface mgmt
    8320(config-if-mgmt)# no shutdown
    8320(config-if-mgmt)# ip dhcp
    8320(config-if-mgmt)# end
    8320#
    Enable SSH on 8320 Switch:
    The following commands will enable SSH access on 'default' and 'mgmt' VRF instance.
    8320-lower#
    8320-lower# configure terminal
    8320-lower(config)# ssh server vrf mgmt
    8320-lower(config)# ssh server vrf default
    8320-lower(config)# end
    8320-lower#
    Enable Web Interface on 8320 Switch:
    In order to enable WebUI access on ArubaOS-CX switch, you need to configure password for the username ‘admin’
    Configuring password for the username ‘admin’
    8320-lower#
    8320-lower(config)# user admin password
    Changing password for user admin
    Enter password: *********
    Confirm new password: *********
    8320-lower# write memory
    Success
    8320-lower#
    Now you can enable the WebUI access on this ArubaOS-CX 8320 switch.
    8320-lower#
    8320-lower(config)# https-server vrf mgmt
    8320-lower(config)# https-server vrf default
    Success
    8320-lower#
    Upgrade image via TFTP:
    The ArubaOS-CX 8320 Switch software image can be downloaded from https://asp.arubanetworks.com/ASP.jpg
    Have the image hosted on the TFTP Server.
    8320-lower# copy tftp://172.30.30.6/ArubaOS-CX_8320_10_02_0020.swi primary vrf mgmt
    The primary image will be deleted.
    Continue (y/n)? y
    Upgrade image via USB:
    You need to enable and mount the USB first using the below commands.
    8320-upper# show usb
    Enabled: No
    Mounted: No
    8320-upper# configure terminal
    8320-upper(config)# usb
    8320-upper(config)#end
    8320-upper# usb mount
    8320-upper#
    Enabled: Yes
    Mounted: Yes
    8320-upper#
    Now perform the upgrade from USB.
    8320-upper#
    8320-upper# copy usb:/ArubaOS-CX_8320_10_02_0020.swi primary
    Continue (y/n)? y
    Verifying and writing system firmware...
    Success
    8320-upper#
    Performing the boot:
    Now boot the system
    8320-upper# boot system primary
    Default boot image set to primary.
    This will reboot the entire switch and render it unavailable
    until the process is complete.
    Continue (y/n)? y
    The system is going down for reboot.
    Hope you find this post useful to get your ArubaOS-CX Switch up and running :)
  • 2.  RE: ArubaOS-CX Switches - Configuring for initial access and performing a software upgrade
    Posted Sep 26, 2020 10:15 AM
    in your example is copy firmware from usb.
    1. how about boot from usb pen drive like Cisco switch did?
    2. what is the format of the usb pen drive. Is it FAT32 or NTFS
    can I use >4GB drive
    tq
