Wired Intelligent Edge
ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
  • 1.  ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
    MVP GURU
    Posted Apr 29, 2019 05:44 AM
    I'm struggling to understand why I obtain two different Distributing/Non-Distributing states for the very same interface of a VSX LAG (lag 10 on our VSX) when I execute two CLI commands that should apparently provide a common result (with regard to the above mentioned states):
    First, please consider the output of show lacp interface multi-chassis for the interface 1/1/19 only member of the 2 ports VSX LAG named lag 10...note that Partner (the local VSX Member, primary node, where I'm logged in) and Remote Partner details (the remote VSX Peer, secondary node) show different results ALFNCD versus only ALFNC:
    Aruba-8320-1# show lacp interfaces multi-chassis
    State abbreviations :
    A - Active        P - Passive      F - Aggregable I - Individual
    S - Short-timeout L - Long-timeout N - InSync     O - OutofSync
    C - Collecting    D - Distributing
    X - State m/c expired              E - Default neighbor state
    Actor details of all interfaces:
    Intf    Aggregate  Port    Port     State   System-ID         System   Aggr
            name       id      Priority                           Priority Key
    1/1/19  lag10(mc)  19      1        ALFNCD  d0:67:26:XX:XX:XX 65534    10
    Partner details of all interfaces:
    Intf    Aggregate  Partner Port     State   System-ID         System   Aggr
            name       Port-id Priority                           Priority Key
    1/1/19  lag10(mc)  1       128      ALFNCD  00:14:5e:99:54:8c 32768    48879
    Remote Actor details of all interfaces:
    1/1/19 lag10(mc)  1019    1        ALFNCD  d0:67:26:XX:XX:XX 65534    10
    Remote Partner details of all interfaces:
    1/1/19 lag10(mc)  2       128      ALFNC   00:14:5e:99:54:8c 32768    48879
    Watching the output above it looks like 1/1/19 on Remote Partner, a Server, is not Distributing...conversely...if I drill down to discover if that difference is found also with commands show lacp interfaces multi-chassis 1/1/19 and show lacp interfaces multi-chassis 1/1/19 vsx-peer I immediately found instead that:
    Aruba-8320-1# show lacp interfaces multi-chassis 1/1/19
    Aggregate-name : lag10(multi-chassis)
                           Actor             Partner
    Port-id            | 19                 | 1
    Port-priority      | 1                  | 128
    Key                | 10                 | 48879
    State              | ALFNCD             | ALFNCD
    System-ID          | d0:67:26:XX:XX:XX  | 00:14:5e:99:54:8c
    System-priority    | 65534              | 32768
    Aruba-8320-1# show lacp interfaces multi-chassis 1/1/19 vsx-peer
                           Actor             Partner
    Port-id            | 1019               | 2
    Key                | 10                 | 48879
    there is no difference - both partner interfaces look Distributing "D" -  for Partner port-id 1 (connected to 1/1/19 on local VSX I'm logged in) and for Partner port-id 2 (connected to 1/1/19 on remote VSX Peer).
    What is the reason for such VSX LAG status difference? Am I misunderstanding those concurrent outputs?
  • 2.  RE: ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
    Posted Apr 29, 2019 05:49 AM
    This is a known bug (fix is not yet here...). Thanks for reporting.
  • 3.  RE: ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
    MVP GURU
    Posted Apr 29, 2019 06:04 AM
    Hello Vincent, OK...is there, in your opinion, a relationship also with a (similar) scenario reported here
  • 4.  RE: ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
    Posted Apr 29, 2019 06:09 AM
    I don't think so, but not sure. I'll check (allow few days).
  • 5.  RE: ArubaOS-CX: Understanding VSX LAG states inconsistency of Partner ports
    MVP GURU
    Posted Apr 29, 2019 06:22 AM
    Thank you.
