Wired Intelligent Edge
last person joined: 8 hours ago
ArubaOS-CX VLAN mirroring
This thread has been viewed 113 times
  • 1.  ArubaOS-CX VLAN mirroring
    Posted Apr 12, 2021 11:22 AM
    I have a couple of ArubaOS-CX switches running OS version TL.10.04.3011. Currently I'm trying to find a way to use port mirroring with specific VLAN's defined as source. I know Cisco switches have this option for many years, but I can't find a way to configure it in ArubaOS-CX. So far I've only found options to mirror an entire physical or LAG interface.
    Is there a way to only mirror a VLAN or a set of VLANs?
    Thank you.
    Martijn Noij
  • 2.  RE: ArubaOS-CX VLAN mirroring
    Posted Apr 13, 2021 12:43 PM
    This functionality is available starting 10.7 on some platforms, but not on 8320.
    Vincent Giles
  • 3.  RE: ArubaOS-CX VLAN mirroring
    Posted Oct 15, 2021 11:10 AM
    Why this functionality isn't available on 8320, it's a hardware limitation ?
    Geoffrey lepers
  • 4.  RE: ArubaOS-CX VLAN mirroring
    MVP GURU
    Posted Oct 16, 2021 05:17 AM
    Hi Geoffrey, it seems that - apart than dealing with an updated Aruba 8230 to be on the safe side (thus working with an ArubaOS-CX 10.7 or possibily at newer 10.8) - of the Aruba 83xx Switch series, only the Aruba CX 8360, speaking about system interfaces' mirroring feature, provides the additional [no] source vlan <VLAN-NUM> [rx|tx|both] CLI command which "Adds or removes VLAN as a source of traffic to be mirrored. More than one source VLAN can be configured in a mirror session. Each VLAN may specify its own direction." this as per latest Aruba AOS-CX 10.08 Monitoring Guide (83xx Switch Series).
    Davide Poletto
  • 5.  RE: ArubaOS-CX VLAN mirroring
    MVP GURU
    Posted Oct 16, 2021 05:41 AM
    Forgot to end my previous reply saying that, to me, it looks like more a software related restriction (a whole command or just an option not implemented) than a hardware one.
  • 6.  RE: ArubaOS-CX VLAN mirroring
    Posted Oct 18, 2021 03:17 AM
    Hi Parnassus,
    Thank you for your information, I hope that future version will allow to have this feature.
    Geoffrey lepers
