ArubaOS (MODEL: Aruba7205), Version 8.7.1.3 - Upgrade needs?
This thread has been viewed 16 times
  • 1.  ArubaOS (MODEL: Aruba7205), Version 8.7.1.3 - Upgrade needs?
    Posted Jun 02, 2023 01:12 PM
    I've just deployed a new Aruba controller 7205 with the OS 8.7.1.3.
    Should i need to upgrade this version to the Aruba recommended one? If yes which one?
    Appreciate your kindly help
  • 2.  RE: ArubaOS (MODEL: Aruba7205), Version 8.7.1.3 - Upgrade needs?
    Posted Jun 02, 2023 03:44 PM
    Whether or not you upgrade will depend on if your access points need it to function or if there is an existing vulnerability or bug that affects you.
    On asp.arubanetworks.com I would choose the LSR (Long Supported Release) checkbox and look at the release notes to make sure your controller and access points are supported.
  • 3.  RE: ArubaOS (MODEL: Aruba7205), Version 8.7.1.3 - Upgrade needs?
    Posted Jun 05, 2023 03:36 AM
    Something to add...
    To evaluate which version of code is supported with which AP Series, here is a matrix which helps you with the solution - https://www.arubanetworks.com/assets/matrix/matrix_WLAN-platforms-software-support-matrix.pdf
    It is always recommended to use an Long Supported Release which is 8.10.x Code train and from this the most recent version. That is 8.10.0.6 as of today.
