Developer
ArubaOS REST API - AnyCLI Truncated Response
  • 1.  ArubaOS REST API - AnyCLI Truncated Response
    Posted Sep 13, 2019 06:10 PM
    Hi all - with duplex not being availabe in the API, I'm trying to use the Cli Command service (/cli) to get the result of a 'show interfaces brief'.
    However, all I get is:
    Status and Counters - Port Status
    | Intrusion MDI Flow
    Port Type | Alert Enabled Status Mode Mode Ctrl
    No port detail at all.
    I have tried a 'show run' and get the full config - so it's not a content length issue.
    Thanks in advance.
    Ben.
  • 2.  RE: ArubaOS REST API - AnyCLI Truncated Response
    MVP GURU
    Posted Sep 14, 2019 04:11 AM
    Hi Ben,
    it is a bug on some old firmware !
    Upgrade and it will be fixed :D
    (you can look https://community.arubanetworks.com/t5/Developer-Community/Known-issue-with-ArubaSW-API/td-p/524351 )
