Wired Intelligent Edge
ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
This thread has been viewed 28 times
  • 1.  ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Aug 07, 2017 02:12 PM
    I'm trying to add a VLAN to a port with an API call. I can retrieve and delete a VLAN from a port (GET .../vlans-ports and DELETE .../vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}).
    Accourding to the documentation a PUT .../vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id} should add the VLAN to the specified port and return VlanPort. Instead the call returns a session id:
    "uri": "/rest/v1/login-sessions","cookie":
    "sessionId=09CG1bRuT5hkCPzI97mmDjpn4uLtsmgkBsAaWUr9h7GxlkbsiASak1PEyj7Ov3n"
    Has anyone succeeded in adding a VLAN to a 802.1q port?
    Link to the documentation:https://www.google.nl/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjX1Neh0b3VAhWLaVAKHWN-BRAQFggmMAA&url=http%3A%2F%2Fh20566.www2.hpe.com%2Fhpsc%2Fdoc%2Fpublic%2Fdisplay%3Fsp4ts.oid%3D7074783%26docLocale%3Den_US%26docId%3Demr_na-c05373669&usg=AFQjCNE0-ggh8-ZTfvY4u7P7pAKaQJcrOA
  • 2.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Aug 18, 2017 07:01 AM
    I think this is a bit different. In this case put is used to change a port mode to tag/untagg for e.g. This can be done in following way:
    vlan_port = { "port_id": "21", "port_mode" : "POM_TAGGED_STATIC"}
     r3 = requests.put('http://192.168.100.1/rest/v1/vlans-ports/1-21', data = json.dumps(vlan_port))
    vlan_port = { "port_id": "21", "port_mode" : "POM_UNTAGGED"}
    But if you want to add port in certain vlan you need to use post:
    vlan_port1 = { "vlan_id": 10, "port_id": "20", "port_mode" : "POM_UNTAGGED"}
    r4 = requests.post('http://192.168.100.1/rest/v1/vlans-ports', data = json.dumps(vlan_port1))
    vlan_port1 = { "vlan_id": 70, "port_id": "21", "port_mode" : "POM_TAGGED_STATIC"}
    Hope this will help you!
    Regards, Dobias
  • 3.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Aug 22, 2017 10:32 AM
    Did this work for you?
  • 4.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Nov 24, 2017 08:10 AM
    Thx, that did it!
  • 5.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Jan 30, 2020 06:32 AM
    Hi Guys,
    I am unble to remove a port(untagged) from a vlan. I am using the following code:
    $sessionId = createSession();
    $url = 'http://IP/rest/v1/vlans-ports';
    $data_array = array(
    "vlan_id" => 93,
    "port_id" => 9,
    $res = callAPI('DELETE', $url, $sessionId, json_encode($data_array));
    The call is not returning anything.
    Please suggest!
  • 6.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    MVP GURU
    Posted Jan 31, 2020 02:34 AM
    @amardeepsingh wrote:
    Hi Guys,
    "vlan_id" => 93,
    "port_id" => 9,
    Please suggest!
    Do you have an error ?
    do you have check log ?
    it will be better to open on Dev section
  • 7.  RE: ArubaOS REST API /vlans-ports/{VlanPort.vlan_id}-{VlanPort.port_id}
    Posted Sep 19, 2023 11:16 AM
    Is it possible to change vlan name for a vlan with REST API?
    And what is the right way to delete a vlan with the rest api?
    I have tried with request.delete("hostUrl /rest/v1/vlans/vlan_idvlan"), but I get error method not allowed.
