Developer
ArubaOS: Set port name/description to blank (via API/REST)
  • 1.  ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Oct 08, 2018 04:19 PM
    I search howto set to default the name/description of port (using PUT method on /rest/v4/port URI)
    but look not possible...
  • 2.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Oct 11, 2018 09:24 AM
    Hey,
    Totally new to the ArubaOS API, but i like APIs so I gave it a shot.
    But I had the same results as you, writing "" or even None/null-types gave me errors:
    {"message":"Incomplete input: name"}
    {"message":"Wrong type for name"}
    And there seems to be no delete methods for this either (not sure if you can delete anything that is a sub-command).
  • 3.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Oct 11, 2018 03:26 PM
    Thanks for feedback... my code is not wrong ;-)
    There is missing feature for this...
    I known there is a AnyCLI but no a good solution for me...
  • 4.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Oct 19, 2018 03:09 PM
    Currently its a bug in the REST API where we have to specify atleast a charecter  to update the port name using API. We will look into fixing it.
    For now you may need to use anycli api option till that get fixed.
  • 5.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Oct 23, 2018 06:50 AM
    There is a number of case/issue ? for following this ?
  • 6.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Dec 03, 2018 03:15 PM
    same issue with DNS... it is complicated to remove DNS name or server... :(
  • 7.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Oct 12, 2018 08:21 AM
    It is not meant to be NULL
    "name":
                "description": "The name of the Port.",
                "type": "string",
                "maxLength": 64,
                "minLength": 1,
                "sql.unique": true
  • 8.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Oct 14, 2018 08:20 AM
    "name":
                "type": "string",
                "maxLength": 64,
                "minLength": 1,
                "sql.unique": true
    Bug on API ? :)
  • 9.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Oct 14, 2018 09:18 AM
    It is documented, so it‘s not a bug.
    The delete option is just missing
  • 10.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Oct 15, 2018 02:38 PM
    it will be strange to get a DELETE for only remove a description name...
    it is a wront definition for this field... i can be null
  • 11.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Jul 01, 2019 02:48 PM
    The key in this resourse will be updated in the AOS-S 16.09 release.
    The name key will allow for a "null" or "zero length" name.
    "name":
                "description": "The name of the Port. An \"\" denotes removal of
               already configured name if exists.",
               "type": "string",
                "maxLength": 64,
                "minLength": 0,
                "sql.unique": true
    with a cURL commnad like:curl --noproxy <switch IP> --cookie "<sessionId cookie>" -i -k -X PUT https://<switch IP>/rest/v7/ports/<port ID> -d '{"id": "7", "name": "testPort"}'a response like this will be returned from the API:
    "uri":"/ports/7","id":"7",
    "name":"testPort",
    "is_port_enabled":true,
    "is_port_up":false,
    "config_mode":"PCM_AUTO",
    "trunk_mode":"PTT_NONE",
    "lacp_status":"LAS_DISABLED",
    "trunk_group":"",
    "is_flow_control_enabled":false,
    "is_dsnoop_port_trusted":false
    or if left empty, curl --noproxy <switch IP> --cookie "<sessionId cookie>" -i -k -X PUT https://<switch IP>/rest/v7/ports/<port ID> -d '{"id": "7", "name": ""}'the respose from the API is:
    "uri":"/ports/7",
    "id":"7",
    "name":"",
    "is_port_up":false,
    "trunk_group":"",
  • 12.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Jul 01, 2019 03:10 PM
    Yes, i have see this but not yet tested... (and there is also some other field where it is complicated to set default value...)
  • 13.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    Posted Jul 03, 2019 05:49 AM
    The updates to the 16.09 API v7 are detailed in the REST guide, these act as the API release notes. See chapter 4:
    https://support.hpe.com/hpsc/doc/public/display?docId=a00076277en_us
  • 14.  RE: ArubaOS: Set port name/description to blank (via API/REST)
    MVP GURU
    Posted Jul 03, 2019 06:32 AM
    Yes Changelog is nice !
