Wired Intelligent Edge
ArubaOS-sw Digital Optical Monitoring (DOM)
  • 1.  ArubaOS-sw Digital Optical Monitoring (DOM)
    Posted Nov 29, 2018 07:59 AM
    Does Aruba switch support Digital Optical Monitoring (DOM)?
    https://community.cisco.com/t5/network-architecture-documents/digital-optical-monitoring-dom/ta-p/3120342
    I'm quite confused about the Diagnostics Optical Monitoring is the same or not.
    http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8162_wb_2920_mcg/content/ch11s05.html
  • 2.  RE: ArubaOS-sw Digital Optical Monitoring (DOM)
    MVP GURU
    Posted Nov 29, 2018 10:06 AM
    You must check (Optical) Transceivers details to understand if DOM is supported or not.
    Look at this guide.
  • 3.  RE: ArubaOS-sw Digital Optical Monitoring (DOM)
    Posted Nov 29, 2018 10:54 AM
    Thanks for the quick reply.
    Just to make sure if I've understood the concept, I can't say that the switch has Digital Optical Monitoring, but the transceiver itself. Is that right?
  • 4.  RE: ArubaOS-sw Digital Optical Monitoring (DOM)
    MVP GURU
    Posted Nov 30, 2018 10:37 AM
    Correct. The switch (both in terms of Hardware and Software) should support DOM but DOM is essentially an Hardware/Software feature embedded into (or not embedded at all, if absent) optical Transceivers.
